visited the dyno today
Old Oct 29, 2010 | 10:07 PM
tofast4uh22's Avatar
Default visited the dyno today
visited the dyno today and the are the results.
setup is vvvvv
sleeved h22, endyne roller wave pistons and manley turbo tuff rods. stock intake manifold, stock throttle body and stock cams-springs-retainers. billet wheel 6265. spoolin performance quick 4 manifold. walbro 255 in the tank and inline bosch 044 with stock fuel lines.
this was on c16 at i think 26psi. tuned by john vega at phearable.net give him a call if you want the best customer service ever. whether it be tuning or just purchasing parts.
Old Oct 29, 2010 | 11:22 PM
93hatched_projekt's Avatar
Default Re: visited the dyno today
Nice power and and very simple setup with tons tq . I too have been wanting to switch to the 6262 on my h22 . Good stuff , now upgrade the fuel lines and valvetrain and see what it will do ....... wrong forum tho ...
Old Oct 30, 2010 | 12:26 AM
FarmYard's Avatar
****in dece.
Old Oct 30, 2010 | 02:27 AM
xenocron's Avatar
Nice numbers, but the waviness at the top of the graph makes me think something is going on with the valves/valvetrain perhaps...keep an eye on that.
You should REALLY have springs/retainers because of the amount of boost you are running. Seat pressure isnt all that high on the stock springs...
Get a 68mm throttle body, port the intake manifold, get some PRO 1 cams, springs and retainers and you'll make the same horsepower at way less boost and be able to rev to ~9000
Old Oct 30, 2010 | 04:17 AM
zakura R's Avatar
Nice h22 Power
Old Oct 30, 2010 | 04:41 AM
you are absolutely right that is my exact plan. we think the waviness at the top of the graph was due to a wierd issue that we had at that exact rpm where the tps went from 100% to 70% for no reason and stayed at that %. it was wierd.
Old Oct 30, 2010 | 06:12 AM
h22 civic's Avatar
what ignition setup...ecu?
Old Oct 30, 2010 | 07:28 AM
KStuned's Avatar
You're not running AEM are you?
Old Oct 30, 2010 | 07:55 AM
sanman000719's Avatar
is this an issue with aem lol
Old Oct 30, 2010 | 08:28 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
almost 500 ftlbs thats rad.
Old Oct 30, 2010 | 08:31 AM
ESP.net's Avatar
Smart Man!
Yes the wavyness up top is exactly from that...
B20luda my engine builder also ran stock H22 Head, cams and valvetrain and made 604hp I believe, meth inj. However valve springs and retainers are a must for insurance, valve float and the reduce risk of serious carnage....
68mm is a must for flow Performance Products makes a good one for cheap. I would invest in either Euro R or Skunk2 manifold for the better flow.
Old Oct 30, 2010 | 09:13 AM
stock ignition.
and esp i am the guy who just ordered that custom up top alternator bracket. it worked perfect.
and no i am on s300
Old Oct 30, 2010 | 12:54 PM
xenocron's Avatar
If your TPS is changing up top...then that waviness is from Ignition Adjustments adding/subtracting timing. Get that ish fixed ASAP!
Old Oct 30, 2010 | 01:07 PM
Mr. Em1's Avatar
damn thats pushing it on stock lines! I would def make those few upgrades and then go back and as Chris said more/ the same power at lower boost levels with a better more consistent curve
Old Oct 30, 2010 | 02:45 PM
hey chris do you know why the tps would drop off up top for no reason.
we checked to make sure that the tps was recieving a full 5v during a pull and it was. we even ran a new wire for the signal wire that runs back to the ecu. i have never seen a tps do that before.
Old Oct 30, 2010 | 03:02 PM
Mr. Em1's Avatar
What kind of tps is it?
Old Oct 30, 2010 | 04:44 PM
stock throttle body and stock tps. we checked it and the voltage is correct.
it was reading correctly all the way up until a little over 6k rpm's and it was the same every time.
Old Oct 30, 2010 | 06:52 PM
xenocron's Avatar
I dont know why that would happen, but if you send me a log...I can take a look.
Old Oct 31, 2010 | 03:37 AM
ralph11sec's Avatar
nice power. does datalog gets disconnected at times on high rpm?
try change tps/add ground.
what AR do you have on that
Old Oct 31, 2010 | 01:56 PM
.81 ar.
datalog doesnt disconnect, thats how i know that throttle position goes down. you can watch the data log and for no reason right at about 6200 the tps drops to about 70% and stays that way and then i think it starts to go back up but then the run is over.
i am going to add a ground to it and try that.
also in hondata you can change the value to where anything over say 60% would be full throttle but for some reason my tuner said it didnt like that.
Old Nov 5, 2010 | 06:13 PM
Sinople1's Avatar
what are the odds of you having a 93 octane tune i have pretty much same setup except a built head but im gonna be running that turbo next season along with a
skunk2 mani and 68mm tb im wondering what kind of number on 93 octane i can expect
Old Nov 6, 2010 | 06:49 AM
sorry man i dont want to sound like a dick, but there are too many variables that could change between our setups which would cause your car to run like **** with my pump gas tune. also its not fair to me or my tuner. its costing him business and i had to pay a lot of money for these tunes. if you are building a similar motor to mine you have a lot of money in it, and its not worth the risk get it TUNED.
you should be able to expect right at 500whp on pump. thats what mine did.
Old Nov 6, 2010 | 08:17 AM
Sinople1's Avatar
no im not asking for a tune i was asking what kind of numbers you made just so i can get a rough estimate of what mine might make next year just trying to get a idea of what that 6262 wil do on pump gas i am already done with my built it made around 460ish whp this year just changing some stuff for next season mainly
sohctodohc
Jun 10, 2021 03:42 AM
pb16b
Jun 4, 2012 06:26 PM
f20b jones
36
Nov 8, 2011 05:53 PM
GRTechnologies
Sep 28, 2004 08:52 AM
hybrid901
Feb 10, 2003 01:28 AM
