Vibrant SFWD Civic Build
Old 04-12-2013, 05:56 AM
  #26
JJsMotorsports's Avatar
Default Re: Vibrant SFWD Civic Build
Nice work! Is this going to be a big tire car? I hope so.....lol
Old 04-12-2013, 06:06 AM
  #27
jc@douglas's Avatar
Looks good guys.
Old 04-12-2013, 06:34 AM
  #28
jdm_ef9's Avatar
Gonna be a bada$$ car!
Looks great guys! Cant wait to see it out!
Old 04-12-2013, 10:47 AM
  #29
DraginX's Avatar
Holy fluffin sock suckers that is Awesome!!
Old 04-12-2013, 10:57 AM
  #30
seelback's Avatar
Originally Posted by JFK78
Thanks to all for the positive comments!
3"in, 3.5"out. The manifold is being ceramic coated which greatly reduces the radiated heat, and those areas of the IC and bumper will be covered with heat reflective material.
The idea behind the manifold was to get as much runner length as possible for max high rpm efficiency and reduced reversion. We also wanted to try something different than the proven forward facing layout we've been using for the last few years.
The car is being built with Vibrant Performance fabrication components to showcase their awesome product line. Skunk2 suspension & engine components will be used throughout as well. It is going to be running a MoTec M800 and 8x Grams 2200cc injectors on FTW Purple, and we'll be doing some testing with the new Borg Warner 72mm units.
We hope to run consistently in the 8's @ 175+mph for starters.
Thats what I like to hear, trying something different. Nice to see you guys trying to shake up the sport and continue to stand out. Sounds like a solid build from beginning to end and your 8 second @ 175+mph goal should be no problem with your experiences!!!
Old 04-12-2013, 11:24 AM
  #31
meane30's Avatar
Hell yeah guys looks great!! Can't wait to see it in Vegas... Not looking forward to being in the same class with it though! Lol
Old 04-12-2013, 12:19 PM
  #32
ej6sir-t's Avatar
Ive always thought too thick of a core would follow bigger is not always better, seems like there would be an increased resistance of flow and the by the time the air got towards the outlet of the cooler the air will have become heat saturated reducing actual cooling capacity compared to a core with a bigger face and less thickness. But im sure you guys have done testing in this design, and its good enough for your needs.
Old 04-12-2013, 08:14 PM
  #33
alopez84's Avatar
Looks great! See y'all in Vegas!
Old 04-13-2013, 12:31 AM
  #34
nonvtecallmotor's Avatar
Looking good!
Good luck!!
Old 04-13-2013, 08:25 AM
  #35
JFK78's Avatar
Originally Posted by 4cylfiend
Looks killer!!! Are you guys going with a closed front end for aero? Is that the reason for the dual core intercooler setup?
Closed front is the plan yes. The short dual core IC setup allowed for the long runners and fitment of everything as we wanted as well.
24.5" SFWD/FWD car, but not saying it won't ever have 26's on it either.
We aren't concerned with airflow through the face of the core - it's a drag car. Front will be closed anyways. We want the core to be low pressure drop more than anything.
Old 04-13-2013, 08:38 AM
  #36
SpeedFactoryRacing's Avatar
Working hard to be ready for Vegas, here's a few more.
Skunk2 Ultra 5.5L Intake Manifold & 90mm TB with Vibrant's V-band flange assembly & polished 3.5" aluminum tubing
Manifold with brace/wastegate/turbo
Through frame rail 5.5" air inlet for the FMW 72mm BW turbo
Old 04-13-2013, 08:44 AM
  #37
seelback's Avatar
I was wondering what you guys were gonna do about the inlet of the turbo. I like the idea though, everything is looking good.
Old 04-13-2013, 01:20 PM
  #38
speeddave's Avatar
Amazing build as always from the speedfactory camp. Can't wait to see the finished product.
Do you have anymore info on the new 72mm from BW? I've been hearing rumours about it, but this is the first one I've seen. Has it been released yet?
Old 04-13-2013, 01:34 PM
  #39
I've been running this turbo since Oct. I went 172mph (Cast) with it on the 2nd pass. I have yet to dial in the car with this turbo. I believe Full-Race has had them for some time now. Paul at DP went 176mph with this turbo aswell. Its a great unit.
This thing makes a lot of power on a lot less boost....
Old 04-13-2013, 02:30 PM
  #40
i want a civic's Avatar
so sick!!
Old 04-13-2013, 02:56 PM
  #41
DC5TypeS02's Avatar
Sick fabrication on the entire build. Love seeing something out of the ordinary
Old 04-13-2013, 06:04 PM
  #42
speeddave's Avatar
Ah ok, thanks for the info. Not meaning to derail the thread, but For some reason I was expecting the FMW 72mm to be like the new billet FMW 67mm.
Old 04-13-2013, 06:16 PM
  #43
They have a billet wheel too..
Old 04-13-2013, 06:28 PM
  #44
redboost10's Avatar
Are you worried about the strength of that frame rail at all? Seems like a big chunk missing from a important part of a fwd car?
Old 04-13-2013, 06:42 PM
  #45
bads2k's Avatar
looks like they welded back inside the hole
  #46
SPOOLINmatt's Avatar
anything forward of where the engine mounts is just along for the ride and not "important"
Old 04-13-2013, 07:38 PM
  #47
redboost10's Avatar
Thank you. I see that now from the front view picture.
Old 04-14-2013, 04:22 AM
  #48
rudebwoy's Avatar
What are you doing to prevent the long manifold runners from radiating the intercooler? seems they are sitting 1/2 from the core. any type of heat shielding?
Old 04-14-2013, 05:40 AM
  #49
Everything is going to be alright guys. Stop over analyzing the manifold near intercooler deal.
Old 04-14-2013, 05:56 AM
  #50
guy_from_nerk's Avatar
Dear guys who have gone fast in everything you put together, you sure you know what you're doing?
Quick Reply: Vibrant SFWD Civic Build
