Valve Float and internal combustion vids
Old Oct 15, 2010 | 09:00 PM
2k.civic.si's Avatar
Default Valve Float and internal combustion vids
Since no one ever looks at the threads i start in tech here ya go
this is neat...check them out
http://www.youtube.com/watch?v=_REQ1...eature=related
http://www.youtube.com/watch?v=i_Npz...eature=related
inside a cylinder
http://www.youtube.com/watch?v=cy_ya...eature=related
Old Oct 16, 2010 | 04:14 AM
h22 civic's Avatar
Default Re: Valve Float and internal combustion vids
nice
Old Oct 16, 2010 | 06:55 AM
harhoosh's Avatar
very nice, thanks for sharing.
Old Oct 16, 2010 | 07:09 AM
SPOOLINmatt's Avatar
wow, you would never think that all of that can happen in the time that it does.
Old Oct 16, 2010 | 10:30 AM
its amazing what high speed camera's can allow us to see these days....i think its awsome
Old Oct 16, 2010 | 10:37 AM
jdm inc's Avatar
awesome!
Old Oct 16, 2010 | 10:58 AM
thundernoodle's Avatar
really cool
Old Oct 16, 2010 | 11:35 AM
spectacle's Avatar
really like the last video, puts things in perspective
Old Oct 16, 2010 | 11:41 AM
lets you see just how much force atmospheric pressure really has once that intake valve opens.
piston moves down creating an area of less pressure and atmospheric pressure moves in to equalize it.
Old Oct 16, 2010 | 05:23 PM
KStuned's Avatar
I love it, gets the gears turning in my head. Would you say that boost pressure relieves valve spring seat pressure as I've thought or does it not work like that?
Old Oct 16, 2010 | 08:25 PM
Pressure behind the valve could only increase valve spring seat pressure as the spring is working against the valve to keep it closed.
Now if your talking about decreasing the force the valve has against the valve seat....boost behind the valve would decrease this.
Old Oct 16, 2010 | 09:29 PM
KStuned's Avatar
Haha yeah sorry, valve seat pressure that's what I meant
Old Oct 17, 2010 | 06:29 AM
unusual71's Avatar
thanks for sharing!!!!
i will be showing this to ALL my gear head friends
Old Oct 17, 2010 | 10:14 AM
Mr. Em1's Avatar
wow those are some really good videos
Old Oct 19, 2010 | 09:27 AM
Turbo305's Avatar
thanks nice video, never had no idea valve spring could bounce at high rpm. cool
Old Oct 19, 2010 | 12:44 PM
sq_creations's Avatar
Nice video's.
Old Oct 19, 2010 | 02:40 PM
pellis90's Avatar
Yes, really insightful video's. I saw the first two a few years ago on youtube while familiarizing myself with valve float and seat pressure, after a failure I might add I have learned a lot since then, and knowing that it happens and seeing it is two totally different things. I love video's like this !! I always could picture the valves moving around and the spring bouncing during valve float but never gave thought to the motor harmonic's spinning the valve spring and valve.
While on the topic, I am going to ask this question because everyone I have asked has provided an different answer, If your cams require a 100psi seat pressure and at WOT you are running 40-45psi, on a turbo set up of course, What seat pressure should you run ?
I have come up with my own little formula but am always insightful of how people answer given you do not want to float a valve and do not want to cause excessive valve train wear.
Old Oct 19, 2010 | 02:59 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I was watching a thing about sts turbo kits on ls series chevy motors and they were saying that stock valve train was fine for like 8-10lbs but anything more then that they had issues with valve float due to the boost pressure pushing the valve down. Iv never seen that issue with hondas before so I thought it was neat.
Old Oct 19, 2010 | 03:03 PM
HRTuning's Avatar
Very cool videos!
Old Oct 19, 2010 | 03:06 PM
pellis90's Avatar
It works like that on Honda's also. Just at different points because they are made to rev higher and have better spring rate and seat pressure to deal with boost from the factory. ( Better Valve Train Stock)
Soccerking3000
Nov 13, 2005 04:40 PM
pwrofdrm
Mar 21, 2005 07:06 PM
graphic
Sep 24, 2004 08:17 AM
