Using different width slicks on the came car?
Old Aug 15, 2007 | 07:27 PM
Tippyman's Avatar
Default Using different width slicks on the came car?
I just picked up a pair of M/T ET Drag slicks for the low low price of free.
Only problem is, one is a 24.5/9-13 and one is a 24.5/8-13.
Can I still use them, or am I going to run into problems?
Old Aug 15, 2007 | 08:34 PM
MAX_CFM's Avatar
Default Re: Using different width slicks on the came car? (Tippyman)
you will crash and die !!!
Old Aug 15, 2007 | 08:48 PM
SlicksMH's Avatar
Pull Pull Pull, wall wall wall = No No No.
John
M&H
Old Aug 15, 2007 | 10:42 PM
ExospeedAMcrx's Avatar
diff side width slicks. oh heeell no. Please dont do that.
Each slick has their own specifications when they are made. Just because it is only .5" difference doesnt mean its exactly that. Slick widths can vary out of the mold from the factory, circumferance can vary, etc.
Even with just a 1/2" width difference, it affects contact patch and how the car will react to the traction. As previously said, it can hook harder on one side and send you to the wall or the other car.
So to sum it up.... please dont use it.
With all the M&H tires that come from us or MandHtires.com, they are sized to match each other. John@MandH will actually measure each tire to make sure that each tire is matched. Even a 1/4 inch difference is noted and matched accordingly.
Old Aug 16, 2007 | 03:30 AM
boostedcivicsir's Avatar
Mr. Badwrench
the height is the same, but the whats the word i learned tractive effort will be different.......
ah hell you will probably crash.
Old Aug 16, 2007 | 05:16 AM
Tippyman's Avatar
Default Re: Using different width slicks on the came car? (boostedcivicsir)
That's what I thought.
Looks like I'll be buying another 24.5/8-13.
Thanks guys.
bignastyb18
Feb 27, 2009 09:30 AM
CRXEE8
Oct 9, 2004 04:40 PM
95c1v1cs1
Sep 16, 2003 01:19 PM
DubyaAye
Jan 8, 2003 01:16 PM
CivicEx95
May 22, 2002 05:19 AM
