Using 5th at the strip??
Old Apr 4, 2005 | 06:53 AM
pbsracerx's Avatar
Default Using 5th at the strip??
I was at the track yesterday and I'm topping out 4th gear before I cross the 1/4 mile line (about 20ft). I see everyone say you should not boost in 5th, so what should I do?
some info:
USDM ITR tranny Quaife LSD
Drag radials
454whp (low boost setting)
redline 9300rpm
best run was
12.7@121
If I get traction in 1st and 2nd I'll definately need more gear or when I run my slicks.
Help is boosting 5th ok?
Or is this a stupid noob question!
Old Apr 4, 2005 | 06:55 AM
g2turbo's Avatar
Default Re: Using 5th at the strip?? (pbsracerx)
You will need to raise your rev limit to probably 9600 or more
here is a gear speed calculator that is very helpful
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Old Apr 4, 2005 | 06:57 AM
pbsracerx's Avatar
Default Re: Using 5th at the strip?? (g2turbo)
I could but above 9000 rpm my power falls off. Not sure if it's because of the cams (ITR) or IM (skunk2) I'm running or....
Old Apr 4, 2005 | 06:58 AM
underpressure02's Avatar
if you run bigger slicks you will prob not need to shift into 5th. When I run my 205/50/15 bfg I have to shift into 5th right at the end of the 1/4 with slicks I am fine
I boost in fifth all the time. Have not blown anything up yet
Old Apr 4, 2005 | 07:00 AM
g2turbo's Avatar
Default Re: Using 5th at the strip?? (underpressure02)
even if the power falls off im sure its better than shifting to 5th. What size slicks do you have?
Old Apr 4, 2005 | 07:02 AM
pbsracerx's Avatar
Drag radials are 225/50/R15
Slicks are 24.5X8X13 on lenso VPD
Thanks for the hlp so far guys!
Old Apr 4, 2005 | 07:04 AM
you should be running a lot better times then that. Even your mph seems low for that much power. On drag radials my best time was 12.6 @ 114 and on slicks 12.3 @112 and I only have about 280 to the wheels.
Old Apr 4, 2005 | 07:09 AM
pbsracerx's Avatar
Passes were on Drag Radials and an unpreped track spinning 1st and 2nd like they did not even exist.
Ps This was my 3rd time at the track ever, so yes some issues are noob related.
Any advice you could give me please??
Old Apr 4, 2005 | 07:15 AM
g2turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbsracerx &raquo;</TD></TR><TR><TD CLASS="quote">Passes were on Drag Radials and an unpreped track spinning 1st and 2nd like they did not even exist.
Any advice you could give me please??</TD></TR></TABLE>
On the slicks, at your current 9300 rev limit you should be able to go 139-140 mph at the very top of 4th.
Just get some more seat time and everything should fall into place. If you are spinning that bad on the drag radials you need to maybe lower the boost in those gears. Id just go ahead and run the slick though with that power
Old Apr 4, 2005 | 07:19 AM
I would not even run dr with that power. Unless you have to. But like the other guy said more seat time and lower boost in those gears would help.
What was your 60 foot times? Also how much pressure were you running in your DR?
Old Apr 4, 2005 | 07:30 AM
pbsracerx's Avatar
It was the first day the track was open here in Ohio so I wanted to get a feel for it since I had only been twice before.
My plan is to run the slicks this coming sunday.
best 60ft was 2.2 at 16psi in the DR
Old Apr 4, 2005 | 09:03 AM
pbsracerx's Avatar
Here's the slip:
From http://www.nationaltrailraceway.com/ Yesterday 4/3/2005
BFG Drag Radials
Running 15-16psi~454whp
R/T = .101
60ft = 2.247
330 = 5.983
1/8 = 8.639
MPH = 91.89
1000 = 10.904
1/4 = 12.757
MPH = 121.52
Old Apr 4, 2005 | 10:53 AM
deftones0817's Avatar
I was shifting into 5th on my drag radials and i ran 12.7 also. I spun through 1 and 2nd gear. I run 24.5 inch slicks but havent had a chance to run them yet. All my times have been on 22 inch slicks. So I think you will see improvement.
Old Apr 4, 2005 | 04:38 PM
torr's Avatar
Default Re: Using 5th at the strip?? (deftones0817)
get slicks brother, i was running m&h, 24's
and around 380 horses and was cutting 1.6's and 94mph in the eigth. i think i ran a 7.9
Old Apr 4, 2005 | 05:01 PM
*Boostwerks*'s Avatar
The slicks have a larger outer diameter. You should be able to trap around 135-140 in 4th at 9500 with that tranny on slicks.
R.A.T.
Sep 9, 2011 09:57 PM
BoostR41
May 18, 2010 11:07 AM
See Are X
Feb 19, 2007 07:22 AM
torr
Aug 8, 2004 05:47 PM
Firedrake
Feb 4, 2003 05:42 PM
