upper control arms recommendations
Old May 16, 2014 | 05:04 AM
  #26
efHondefender's Avatar
Default Re: upper control arms recommendations
Originally Posted by Tippyman
Keep your factory "bushing brackets" that are on the stock arms. They will fit into the Skunk2 arms if you ever wanted to have Kingpin do the bushings.
Right now I have my new Skunk2 arms bushing-less and my parts car has some shiny new Skunk2 bushings on the factory arms! Lol.
I was actually planning on doing the same in the future. Right now, that would be some serious overkill. I'm only rocking about 80whp at the moment. LOL. I'm still building the motor that will replace the original.
Old Jan 18, 2016 | 07:37 AM
  #27
red96turbols's Avatar
Originally Posted by hondatech8798
Been trying to get PCI solid brass bushings for my upper and lower arms for my civic..
Been waiting on production on them for a good 4-5 months directly through Brian at PCI .. They seem to be a better solution to stock rubber bushings and cheaper than spherical, just gota get ur hands on em
Did you ever get these? Reason I ask is JHP has them in stock as does PCI again and my Junk2's have had enough. I'm tired of replacing the garbage *** ball joint they have every year when this car only sees maybe 3,000 miles /year. Searching for a new company with a stiffer upper arm and better joint since this car can't keep the front end together anymore. For the money they seem nice, but can't really find anyone who has had them and how they've worked out etc. Thanks.
Old Jan 18, 2016 | 08:38 AM
  #28
rudebwoy's Avatar
Truhart
Old Jan 18, 2016 | 10:07 PM
  #29
Bently_Coop's Avatar
Steve at Heart
Originally Posted by efHondefender
Ok. So I went with the Skunk2 Pro Plus arms. They just seemed to have a better bushing area design than the competition. The buddy clubs basically looked the same as the regular Skunk2 pro series. I thought the hard race arms looked like every other chinese upper arm in the world just rebadged. Here you go: Civic Adjustable Upper Control Arm-Civic Adjustable Upper Control Arm Manufacturers, Suppliers and Exporters on Alibaba.comAuto Control Arm
Go start your own chinese control arm company. LOL
If I were gonna run something like that, I'd say TruHart arms get an honorable mention for improving on the balljoint design.
Now I know there has been a lot of things said about skunk2, but most of what I read is pretty ill-informed. People seem to bash the products because they are made overseas. Well, so are my blue point and mitutoyo tools. Where it's made isn't nearly as much of an issue as who did the engineering and what materials and quality control is specified. Iphones and Xboxs are made in China and people love that ****.
I also read about bushings failing. Most of these arms have rubber bushing with no ability to rotate other than it's twisting compliance. That said, the bolts that mount the bushings shouldn't be tightened until the car is on the ground at ride height or ride height is simulated. I can just picture a bunch of 17 year old kids having their suspension at maximum travel and tightening the bushings down and then taking the car off the stands and having it sit mad JDM hella tucked. The rubber probably tears immediately. It should be noted that the Skunk2 pro plus utilizes freely moving urethane bushings instead of the usual pressed rubber.
It is all made in Taiwan, do not be fooled by lipstick on a pig.
PCI has some Camber kits and bearings available. Which chassis do you have?
Originally Posted by rudebwoy
Truhart
TruHart is just recolored Hardrace stuff.
Old Jan 21, 2016 | 08:10 PM
  #30
Dorkenheimer's Avatar
I, too, have had problems with my Skunk2 ball joints. Just had them replaced after 2 years of driving on them. Granted I work in a part of town with potholes and lots of train tracks. Sometimes I don't see the potholes or hit the tracks a little too fast. My work premises is also dirt/gravel. Which means my ball joints see lots of rocks, mud, and tons of dust in the summer. They get abused quite well.
Also have had a reoccurring bushing squeak from one camber arm bushing. Same one keeps coming up. I just spray vegetable oil on it now and it disappears for months haha.
Old Jan 23, 2016 | 11:15 AM
  #31
rudebwoy's Avatar
I have Truhart in the front, and Hardrace in the back for upper control arm camber kits.
CivicSiRacer
27
Apr 14, 2015 05:26 AM
venomzz
Dec 4, 2007 11:56 AM
sifoo
Suspension & Brakes
Jul 9, 2006 06:20 AM
revlimitcrx
Suspension & Brakes
Nov 28, 2005 06:49 AM
FormulaIntegra
17
May 27, 2005 11:59 AM
