twin inline bosch 044's
im preparing to upgrade my fuel setup. my questions are: which AN fitting from my -8 line into the first bosch? which fitting do i get for in between the 044's? which AN fitting exiting the sec 044 to a -8 line? thanks in advance for your time and help on this...
Sorry to not answer your questions, but what pressure and HP are you looking to make? What fuel and what injectors?
I've ran 044's in parallel at 80 psi base and 117 total psi with no pressure loss.
yeah you will need a shitload of pressure then.
It would be cheaper to get the ID2000cc before the dyno, tune it once.
ID 2000cc, 4 bar base, and 2x 044's in parallel will do that power easily.
the new aeromotive pro series is being used by a few people on here with e85 and id2000's man
one has made 840, and the other over a 1000
i was also looking at dual 044's, and the pro series then i seen them post what they was doing with the pro series and that made my mind up
spoolinmatt is one of them
nonono the newer pro series pump man here is the thread
https://honda-tech.com/forums/forced-induction-16/aeromotive-pro-vs-dual-bosch-044-a-3010263/
So far my favorite thing to use with the 044's is this surge tank. I wish I had one of these years ago. lol
http://www.intengineering.com/Integr...15580-1-2.html
We've been running surge tanks for years.... can't believe you guys put up with that sumped tank BS for so long.
Now I wish that Bosch would just make an "088" pump, LOL.
I really like Radium Engineering's Surge Tank Kits.
http://store.radiumauto.com/index.ph...id=51&parent=5
Wouldnt he need to run a sumped or surge tank? I know you can make 700whp on Walbro 255 intank with bosch 044 single on gas
The sumped oem tank or external surge tank is to ensure a steady supply of fuel to the pressure pump. I prefer the surge tank because you can run the oem tank with far less fuel in it and still not run into supply issues.
that radium surge looks sharp... so i soldmy kpro and bought a aem v2. is 50psi a good base for fuel pressure..i have a walboro 255 and Id 1000's stock fuel setup as of now. jus waiting for my boschs to arrive so i can sump the tank.....
