transmission choice
Old Mar 19, 2007 | 04:59 PM
TypeSLO's Avatar
Default transmission choice
i have a stock Si trans and an LS trans. setup for about 500 whp or more. which would you guys prefer for drag racing and WHY?
Modified by TypeSLO at 6:24 PM 3/19/2007
Old Mar 19, 2007 | 05:18 PM
ExospeedAMcrx's Avatar
Default Re: transmission choice (TypeSLO)
If I had some cash to spend, liberty trans.
DaveF's Avatar
Default Re: transmission choice (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">If I had some cash to spend, liberty trans. </TD></TR></TABLE>
haha wouldnt we all
b16
Old Mar 19, 2007 | 05:29 PM
Turbocivic94's Avatar
B16- shorter gears
Old Mar 19, 2007 | 05:33 PM
TypeSLO's Avatar
Default Re: transmission choice (Turbocivic94)
so you guys actually shift into fifth at the end of the run? just curious. thanks.
Old Mar 19, 2007 | 05:35 PM
DaveF's Avatar
rev the **** out of the engine.... if you have a good setup it will still be making power.
Old Mar 19, 2007 | 05:49 PM
TypeSLO's Avatar
Default Re: transmission choice (dturbocivic)
i'm not so worried about not making power. it's that when i was using the b16 tranny on another setup, i had to either keep it pegged at redline in 4th gear or shift into 5th. but i know a lot of you guys are running good times so i'm guessing you're using your 5th gear?
Old Mar 19, 2007 | 06:00 PM
factors that can determine what gear you'll end up at.
1. tire size
2. trans gearing(type and FD)
3. RPM shift point
4. wheel spin
5. HP
you just have to calculate everything to see which is best for you.
Old Mar 19, 2007 | 06:07 PM
TypeSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">factors that can determine what gear you'll end up at.
1. tire size
3. RPM shift point
4. wheel spin
5. HP
2. stock b16
3. 8900
4. minimal
5. currently a little over 400whp and a little over 300ftq. will be over 500whp soon.
have no idea what gear i'm gonna end up in without actually putting each trans on which i'm trying to avoid.
Old Mar 19, 2007 | 07:16 PM
Meat_Wagon's Avatar
http://www.fatboyraceworks.com...are=1
Here is a gear ratio calculator
Old Mar 20, 2007 | 01:00 PM
TypeSLO's Avatar
Default Re: transmission choice (Meat_Wagon)
that's an awesome calculator. guess it only works in a perfect world but it's a good start. thanks.
Mr. Chainsaw
Oct 16, 2008 06:48 AM
slammedobd1teg
Sep 25, 2008 02:31 PM
mike devins
Jan 11, 2008 06:12 PM
98gsrTEG
Apr 3, 2005 08:11 AM
milruner
15
Aug 25, 2004 10:14 AM
