transmission
Old Oct 23, 2003 | 05:58 AM
kaimo's Avatar
Default transmission
Hello.
I am woundering, how much power can handle stock D16Z6 transmission?
Im running a 400hp now and no problems, can it handle a 600-700hp?
Kaimo
Old Oct 23, 2003 | 02:24 PM
speedworks's Avatar
Default Re: transmission (kaimo)
i seriously doubt 400 hp on a d series trans with no problems.
Old Oct 23, 2003 | 02:50 PM
ZEX Man's Avatar
Default Re: transmission (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">i seriously doubt 400 hp on a d series trans with no problems. </TD></TR></TABLE>
I am making about 480 whp and have no problems with my ZC transmissions. The really important part is figuring out your clutch. I tried a really aggresive sintered iron disk and started breaking trannys every 6 passes.....changed to a slightly less aggressive compound and haven't broke one yet (25 passes and counting) I had over 200 passes on my first tranny, I was only making 375 whp at the time, before it finally broke second gear. I was using a copper ceramic style disk. The clutch is the key to making your trans. live.
Later,
ZEX Man
Old Oct 23, 2003 | 04:09 PM
D-Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaimo &raquo;</TD></TR><TR><TD CLASS="quote">Hello.
Kaimo</TD></TR></TABLE>
I hate to bust your bubble but your not gonna put 600-700hp thru a D16Z tranny unless you bolt a B or H to it
BTW...can we get the details of your 400hp set-up?
Old Oct 23, 2003 | 09:12 PM
red cx's Avatar
man thats some crazy hp on a d series transmission. I dont think the tranny would like that to much.
Old Oct 23, 2003 | 10:16 PM
kaimo's Avatar
Default Re: transmission (D-Man)
Wiseco pistons
Eagle roads
580cc injectors
Hestec engine management
stock cam
Laki Tuning intercooler
Laki Tuning bov
Laki Tuning turbo manifold
JS wastgate 14-60psi
stock intake manifold
Schwitzer S2B turbo
comp cams valve springs
ACT race cluch
12psi 328whp
22psi 402whp
Im planing a run with Garrett GT 37, with comp cams stage 2 cam, costom intake manifold, liquid intercooler and stock sleeves. Planning a 600whp.
Old Oct 23, 2003 | 11:57 PM
slowsi00's Avatar
12psi 328whp
22psi 402whp ---
stock sleeves. Planning a 600whp.</TD></TR></TABLE>
go for it
dyno vid
u will be pimp status on pushing stock sleeved d series block to 600whp
Old Oct 24, 2003 | 12:50 AM
MackSpeed-616's Avatar
Default Re: transmission (slowsi00)
matt patrick is the man!
Old Oct 24, 2003 | 02:26 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: transmission (MackSpeed-616)
600hp on stock sleeves, huh? What are you smokin
Old Oct 24, 2003 | 03:41 AM
D-Man's Avatar
Im planing a run with Garrett GT 37, with comp cams stage 2 cam, costom intake manifold, liquid intercooler and stock sleeves. Planning a 600whp.</TD></TR></TABLE>
two things...forget about the GT37..get the GT35R cause its dual ball bearing and can support those HP numbers...and 2nd ditch the stock sleeves and go with aftermarket ones so you can increase the displacement to around 1800cc.Also,the stock sleeves will never hold at the psi level you'll need to make 600-700hp which would be well north of 40psi.
Modified by D-Man at 9:41 AM 10/24/2003
Old Oct 24, 2003 | 05:20 AM
sihatch19's Avatar
thats hard to believe
Old Oct 24, 2003 | 05:41 AM
kaimo's Avatar
Default Re: (sihatch19)
stock sleeves can handle this kind of power, its all obout tuning and balancing.
If the sleeves are ported wright and... they will hold some time.
I have a costumers car who is running a D engine 531 whp daily.
Its all obout tuning guys.
Old Oct 24, 2003 | 05:47 AM
D-Man's Avatar
Default Re: (kaimo)
BTW....where the hell is estonia? is that near Fantasy Island??
Old Oct 24, 2003 | 05:51 AM
kaimo's Avatar
I think it will be your fantasy to get that much hp with stock sleeves, its duable.
Old Oct 24, 2003 | 06:47 AM
Civic TSI's Avatar
Default Re: (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If the sleeves are ported wright and... </TD></TR></TABLE>
Huh ?
stevieteg
Transmission & Drivetrain
Mar 1, 2009 06:07 PM
Deano_D aka "Brick Top"
Sep 22, 2008 08:37 PM
auburnBoy
Oct 3, 2005 05:39 PM
soundman
Sep 9, 2003 08:29 AM
Ricey McRicerton
11
Sep 8, 2003 04:33 PM
