Traction bars
Old Jul 29, 2003 | 04:30 AM
Civic TSI's Avatar
Default Traction bars
Ok, I got my JimFab tractions bars but first I need to redo my IC piping to make it fit. In his letter, Jim say that first to try the bars with zero preload and adjust accordingly if necessary. I was wondering, how does the preload works ? What's the effect if we tighten the bars ? What about if we loosen them up, meaning making them longer ?
Old Jul 29, 2003 | 08:43 AM
92h22a's Avatar
Default Re: Traction bars (Civic TSI)
Do they look anything like these.
Old Jul 29, 2003 | 09:36 AM
mskibbz-T's Avatar
Default Re: Traction bars (92h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92h22a &raquo;</TD></TR><TR><TD CLASS="quote">Do they look anything like these.</TD></TR></TABLE>
Pretty similar...
Old Jul 29, 2003 | 11:49 PM
J2turbo21's Avatar
Default Re: Traction bars (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">
Pretty similar...
I got me some of these also
Old Jul 30, 2003 | 12:16 AM
turbospool's Avatar
Default Re: Traction bars (J2turbo21)
for cars with the compressor on the driverside with the intercooler piping running by the oil pan, wouldnt the bars hit the piping as the suspension travels?
Old Jul 30, 2003 | 02:37 AM
DSF's Avatar
DSF
.</TD></TR></TABLE>
Is it me or do the lower control arm brackets look like they are reversed? Those heim joints look to be at horrid angles.
Old Jul 30, 2003 | 11:28 AM
turbospool's Avatar
Default Re: Traction bars (DSF)
could be. but guys with traction bars. when you car is on the ground do the traction bar links sit higher than the bottome of the oil pan? if so by how muich? im trying to see if i could use them as well because my intercooler piping is about half way up teh oil pan and i dont want hte bars to hit it.
Old Jul 30, 2003 | 02:15 PM
SiR Kid's Avatar
New User
Default Re: Traction bars (turbospool)
Here'a pic of the clearance on mine... it's an ED chassis, though.
Old Jul 31, 2003 | 01:08 PM
ComposiMo's Avatar
Default Re: Traction bars (SiR Kid)
Last day of the GB for JimFab.... Get em while they're hot!
https://honda-tech.com/zerothre...08232
Old Jul 31, 2003 | 01:09 PM
turbospool's Avatar
anybody have pics of those bars on a integra dc2 chassis? how much more up do the bars go when the car is on the ground? thanks
Old Aug 1, 2003 | 07:37 AM
Cm91h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSF &raquo;</TD></TR><TR><TD CLASS="quote">
Is it me or do the lower control arm brackets look like they are reversed? Those heim joints look to be at horrid angles. </TD></TR></TABLE>
That is the only way the bars would clear the h22 oil pan.
Old Aug 1, 2003 | 07:58 AM
HotRodDelSol's Avatar
Default Re: Traction bars (Cm91h22a)
I just put mine on the del yesterday- I tightened them up after the car was on the ground. It drove really well after I tightened them a little, so I haven't loosened/tightened them any more.
setting preload at zero when I first got them on:
final install on passenger side:
Old Aug 1, 2003 | 11:44 AM
turbospool's Avatar
do you think you can take some pics with the car on the ground and turn the wheel all the way to the left so i can see the clearance between the bar and the oil pan? My charge pipe runs there because of the rev hard 2c manifold and i dont want to buy something that would hit it and not fit correctly.
by the way, are those painted nails?
Old Aug 1, 2003 | 12:35 PM
Default Re: (turbospool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbospool &raquo;</TD></TR><TR><TD CLASS="quote">do you think you can take some pics with the car on the ground and turn the wheel all the way to the left so i can see the clearance between the bar and the oil pan? My charge pipe runs there because of the rev hard 2c manifold and i dont want to buy something that would hit it and not fit correctly. </TD></TR></TABLE>
Yes, but it'll be next week sometime
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbospool &raquo;</TD></TR><TR><TD CLASS="quote">by the way, are those painted nails? </TD></TR></TABLE>
Yea- is there something wrong with having a manicure and working on your car?
Old Aug 1, 2003 | 06:06 PM
T4eg's Avatar
Default Re: (HotRodDelSol)
jimfab traction bars is an awesome product IMO
Old Aug 1, 2003 | 09:30 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: (BlueHatch00)
Ok, can someone tell me if I am on crack or what, but these look to be on backwards. I am looking at the mount on the inboard end of the torsion style bar. The attachement anchors look to be waaaay too highly streesed for me. Or are they supposed to look like this??
Clayton
Old Aug 2, 2003 | 01:11 PM
turbospool's Avatar
Default Re: (Clayton)
it wont clear the tranny or oil pan if mounted the other way...
Old Aug 3, 2003 | 08:11 AM
kwik93si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clayton &raquo;</TD></TR><TR><TD CLASS="quote">Ok, can someone tell me if I am on crack or what, but these look to be on backwards. I am looking at the mount on the inboard end of the torsion style bar. The attachement anchors look to be waaaay too highly streesed for me. Or are they supposed to look like this??
Clayton</TD></TR></TABLE>
hey clayton...those are on backwards...mine are the same bars and fit fine w/ my h22
Old Aug 3, 2003 | 10:39 AM
Clayton's Avatar
H-T Administrator
25 Year Member
After looking at those pictures, I can see what you mean about the clearance issues, but doesn't having those bars mounted in the manner defeat the purpose of having the traction bars at all? If the force applied to the bars is intended to travel the length of the bar (I think that makes sense) and the force cannot travel, it is all forced to the angle of the mounting bracket, which (the way I would see it) would simply break the mounting points over time, and in which case purchasing those bars just proved to be a very expensive waste of time. Why not look at the way the motor was mounted and see if you couldn't raise the motor to get the necessary clearance for the bars. Or see if any other companies traction bars fit better with the H22 in a Civic???
Clayton
Old Aug 3, 2003 | 10:57 AM
95hbMatt's Avatar
I can't wait for my JimFab traction bar to get here! It's on it's way!
also wondering about adjustments and the affects of the adjustments.
Old Aug 3, 2003 | 05:28 PM
Civic TSI's Avatar
Default Re: (95hbMatt)
Well, I finally installed them. I can feel the difference just by depressing the clutch in first or reverse but I still have wheel hop right now, I'll play with the ajustment tomorrow.
Old Aug 3, 2003 | 06:47 PM
EFb18b's Avatar
Default Re: (Civic TSI)
Keep us updated I'm also curious as to how well these things work
Old Aug 3, 2003 | 10:07 PM
kwik93si's Avatar
Default Re: (Redlineracer)
i use hasport mounts w/ my h22 setup and use the same traction bars...totem industries...w/ no clearance issues.
Old Aug 5, 2003 | 04:31 PM
Civic TSI's Avatar
I readjusted the bars with some preload and it felt like **** just driving the car. I put them back at zero preload but this time at ride height and it feel much better, wheel hop is almost gone. Now I have to redo the IC piping to further test it.
Old Aug 5, 2003 | 10:25 PM
turbospool's Avatar
which side is your compressor on?
