Tires for dyno....
Tires for dyno....
I tried using some BFG drag radials, 225 wide,( I believe) to dyno my car with some success. However once the car hit around 750 hp, we could not keep it from spinning on a Dyno Dynamics dyno. Even using 6 straps pulling the car down and into the rollers. My question is, what size and type of tires is everyone having success with for dyno purposes?
Re: Tires for dyno....
I had heard the VHT trick, guess it may be time to give it a try. I thought that maybe there was a wheel and tire combo that someone had figured out.
Also look to see the wear on the tires you have. Inflation of the tires also matters when dynoing a car. It will also matter the way the straps are routed. Is there over lap of the straps to keep the pressure down?
I bought some 265/50-15 tires to try on the Dyno Dynamics. Hopefully this is enough tire to get me well past 750. GoldieWang, I dont really attend car meets anymore. The closest thing to a meet I go to is the drag strip. I usually run the Civic in the Outlaw events at Knoxville Dragway and Brainerd Dragstrip.
