tire shake?
Old Dec 2, 2006 | 07:01 AM
ALL IMPORT's Avatar
Default tire shake?
well i noticed on the dyno at high boost the tires got some seriouse shake & were slipping cause i made less power than low boost did . wondering if that is normal sh*t. should i put vht on them. also i am on BFG RD at 10psi in the tire.
also noticed i got it on the street from time to time as well is that just the tires on the verg of hooking & slipping or what cause it feels like the car is going to fall apart.
the car runs like a beat spins all 4 gears on the street if u want it to on low boost. but normally u can pedal 3rd to get some speed them 4th hooks after about a sec. but its 3rd that shakes cause second just rips nasty loose. thats why i think its just on the verg of hooking & spinning.?
any input will be nice.
Old Dec 2, 2006 | 08:55 AM
Boner_Ben's Avatar
Might want to try different strapping techniques on the dyno.
Old Dec 3, 2006 | 09:41 AM
ykracing's Avatar
Default Re: (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">Might want to try different strapping techniques on the dyno.</TD></TR></TABLE>
i agree...
Old Dec 3, 2006 | 11:36 AM
Bisimoto's Avatar
Default Re: (ykracing)
Your experience is one of the key reasons that I prefer dynapack hub dynamometers. You also do not have to deal with the variables introduced by tyre growth, tire heat, loss of traction, and "strapping loads". My 2 cents.
Old Dec 3, 2006 | 03:31 PM
sewell94's Avatar
put some more air in the tires when your on the dyno, that'll also throw your numbers off, what type/kind of dyno where you on??
Old Dec 3, 2006 | 04:28 PM
ALL IMPORT's Avatar
Default Re: (sewell94)
mustang awd dyno. also with more air it was worse.
no one really answerd my ???? is just from traction issues on & off the dyno?
what about vht on the tires?
aslo ive been thinking about putting 2 new straps basically straight down & cross them on the floor to pull down harder
Old Dec 3, 2006 | 04:31 PM
Jared's Avatar
run 4 straps in the front, 4 straps in the back, and dont use slicks or vht and you'll be fine
Old Dec 3, 2006 | 04:37 PM
boostedh22a's Avatar
Crossing the straps helps tremendously and we have found that if you don't pull all the way on top of the roller, this also helps with tire spin.
Old Dec 3, 2006 | 05:01 PM
ALL IMPORT's Avatar
Default Re: (boostedh22a)
on the mustang u are between 2 rollers, i just got to change the technique
ImPuLsIvE
May 30, 2008 10:05 AM
b16 matt
Sep 15, 2006 12:18 PM
Drew Peacock
Sep 19, 2003 05:58 PM
