Tire selection
Old Mar 25, 2013 | 10:38 PM
guttamane2486's Avatar
Default Tire selection
Need some advice on tire type and size. I have a 95 ls in the process of putting a 75 shot on the car it is just a simple intake header exhaust and zex kit and will be tuned on Neptune which I'm hoping to make around 220 hp and I'm hoping to see 12.80s. I just wanted some advice on what tire along with some seat time will ibest benifit my setup and allow me to be able to see some consistant times . I was looking at a set of G-force T/A drag radials 205/50/15 and a set of MH 8 x22.0-13 slicks please chime in with recomendations .
Old Mar 26, 2013 | 09:19 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Tire selection
Sounds like you have the right idea. I was going to go with 22" slicks but with me stepping up the hp to 300ish I went with M&H 23/8.5-15. My street setup are Dunlop z1 star specs 205/50/15 which have been awesome tires in dry and wet. They have had good wear as well.
Summit was the best price until I found this discount code. Summit is also known for not sending matching sets from what I have heard.
I just got a 16% discount on MandHtires.com by using a discount code: DAKOTA-DURANGO.COM from 2007.
Old Mar 26, 2013 | 09:27 AM
crazes's Avatar
Moderator
I would go with 23 for your setup on slicks. The day to day those should be fine
When it comes to you I would go to 24's and if you can get an smaller rim which would benefit you more also than running on 15's you currently have right now.
95Type-R
Jun 30, 2012 06:00 PM
90Rexx
Aug 24, 2010 04:35 PM
DelSolMarine
Jul 21, 2010 07:17 PM
karmadhi
May 24, 2008 07:26 PM
theERAisBack
Feb 15, 2008 08:18 PM
