Timing Question
Old May 12, 2004 | 02:33 PM
TK715's Avatar
Default Timing Question
gotta jdm gsr with aem cam gears, 255 walbro fuel pump and im shooting 75 shots. question is what degree (advanced or retard) should i set my distributor too for the engine's max potential?
Old May 12, 2004 | 02:35 PM
TK715's Avatar
Default Re: Timing Question (TK715)
not max potential but for the best results
Old May 12, 2004 | 03:22 PM
TK715's Avatar
anyone?
Old May 12, 2004 | 04:09 PM
H25's Avatar
H25
if your sparying you generally want to back off some timing i think its about 4 degrees retard for every 80hp shot. somewhere along those lines.. stock is 15 degrees btdc.. so go from there. with colder plugs.. heat up the bottle and Go for it..
Old May 13, 2004 | 09:06 AM
here2race-no.b.s's Avatar
Default Re: Timing Question (MHRacing-310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">if your sparying you generally want to back off some timing i think its about 4 degrees retard for every 80hp shot. somewhere along those lines.. stock is 15 degrees btdc.. so go from there. with colder plugs.. heat up the bottle and Go for it..</TD></TR></TABLE>
Tippyman
Nov 22, 2005 09:11 PM
yeegsr
15
Jan 4, 2005 07:36 PM
SOHC_MShue
Nov 30, 2003 07:54 PM
silver4
Mar 12, 2003 03:24 PM
honda8882
Sep 29, 2002 11:28 AM
