Timing for high boost
Old Feb 23, 2012 | 05:35 AM
furd's Avatar
Default Timing for high boost
What are most guys using for timing when running high boost 35-40-50psi and more, thru the lights at the end of the track, Highest and lowest... Thanks in advance, furd
Old Feb 23, 2012 | 06:01 AM
sc_at_QuaifeUS's Avatar
Default Re: Timing for high boost
if you want a beneficial reply, you should specify a fuel and a few details about the build...
Old Feb 23, 2012 | 06:18 AM
furd's Avatar
Just a generalized question. Those who answer can add. Just mention if your on gas, meth,e85 or what. I know everyones thinking is differant. I guess my main question would be is, and this may sound odd, but who has ran there timing back the furthest, with good results? I know of some that are back as far as 12 degree's at 55psi out the back door and is anyone back farther than that?
Old Feb 23, 2012 | 06:54 AM
BCEK's Avatar
C16, k20 9.0-1, 67mm,
18-20 at 20 psi
16-18 at 30 psi
14-16 at 40 psi
Old Feb 23, 2012 | 07:19 AM
E Town DSM's Avatar
What does your tuner think?
Old Feb 23, 2012 | 08:42 AM
tony1's Avatar
Might want to add what ecu and trigger setup you're using as well. And then keep throwing darts at the board.
Old Feb 23, 2012 | 08:47 AM
sanman000719's Avatar
lol
gone fishin
Old Feb 23, 2012 | 11:46 AM
MadVTI's Avatar
99 pump fuel, billet 5857, b18c4 @ 9.5-1, 14 degrees at 22psi
Old Feb 23, 2012 | 01:22 PM
kc03e46's Avatar
30 degrees timing 30 psi on pump gas on a stock 8 valve 1.5L honda cx motor!
Old Feb 23, 2012 | 01:58 PM
BCEK's Avatar
Haha love it
Old Feb 23, 2012 | 02:09 PM
nonvtecallmotor's Avatar
Taking advise for timing on the internet is stupid...... Ever car can be different. Not all ECU, Triggers, Fuel, Weight, Cam, CR, Stroke and Gearing are the same....
There a car that i play with that runs as low as 11 degrees @ 30psi, but thats what the car WANTS... My car would not even run at 11 degrees lol.
Old Feb 23, 2012 | 03:32 PM
rayray24's Avatar
Where does it say he needs advise or is going Fishing?
Just saying....
Old Feb 23, 2012 | 03:49 PM
furd's Avatar
Its just something ive wondered as far as the differant make and models are concerned. Not try to start any kind of debate, but ive been quicker than probably 75 percent of the racers here. Below is a picture of my car from Rockingham last year, Two weeks before barrel rolling it down the track breaking my back, neck and dislocating my sholder... So in other words im not looking for advice just wondering what other engine designs like.
This perticular pass was 8.22 on only the cars 30th pass, and had never been on a dyno, track tuned
http://www.youtube.com/watch?v=3e-kxluQL78
http://www.the****.com/pics/photo_13...33443fbecb.jpg
Old Feb 23, 2012 | 05:25 PM
crucian's Avatar
The OP wasn't asking for advise. It is a legit question. I run low 20degrees@30psi on E85. 2.0l, 9.3 compression, low overlap turbo cam.
Old Feb 23, 2012 | 08:06 PM
SwappedTURBOegg's Avatar
aem s1 on an epm been tuning my self since forever i just look at the plugs never been past 30psi but the 50 psi has me curious. and i have seen some 2jz tunes and evo tunes like 5 degrees of timing,it doesn't seem right. is every motor THAT different? or are us honda guys ahead of the game?
Old Feb 24, 2012 | 07:09 AM
mikesrex's Avatar
anyone running pump gas? 93 octane, stock B16 motor, precision 6076, 20 lbs 12-13 deg right now on Neptune
not high dollar but it's a fun car to drive knowing I have hardly anything in it
miro_gt
Sep 19, 2005 02:17 PM
boosted k20
Aug 28, 2005 06:39 AM
WadeH
Jul 25, 2005 11:01 PM
Jared
Aug 28, 2002 10:12 AM
Lei Siew Long
May 7, 2002 08:39 AM
