time slip help
60=1.832
330=4.953
1/8=7.21@105.72
1000=9.212
1/4=10.815@141.33
my quest thi summer was for mid to low 10's, but my 60' times kill me.
what could i expect with a 1.6 60'
i did manage a 10.4 with a 1.72 60" but still not in the 1.6 range like it should be
330=4.953
1/8=7.21@105.72
1000=9.212
1/4=10.815@141.33
old rule is, a tenth off the bottom = 2 up top.
but thats not always true especially with our cars, as we really dont start applying the power til after we are moving.
my cars 9 sec pass had a 1.72 short time.
A friend gave me some tires that were fairly fresh (about 4-5 passes on them ) And on the first hit it went a 1.67 not changing anything in the way i drive.
yeah new tires are in the new plans for winter
ive seen people runni ng the mfactory 1st gear most of them cut low 1.6 high 1.5 does this factor in since im on a stock gsr tranny
i am (well was) on a 100% stock GSR trans with a ITR diff. And i have 12 slips on that tranny and 8 of them were 1.6s
gotcha
the 1.72 60' is my best and was my last pass as well before a rod bolt fell out and caused damage
my tuner had siad my rpms were falling back to far from 2 step to launch we went to medium cut from soft and thats when it got the 1.72 then i turned it up from 19psi to 22psi to see what it would do and well it didnt make it out the water box lol
You definately have more left in the car. Heres what my short times look like and i feel like my car still needs a good bit of work to get the 60 and 330 where i want it.
1.70 60ft
4.71 330ft
7.16 1/8th @ 99 mph
11.01 1/4 @ 130 mph
Car made 360whp on 16 psi this run was on 20psi, no boost by gear yet.
1.70 60ft
4.71 330ft
7.16 1/8th @ 99 mph
11.01 1/4 @ 130 mph
You wouldn't believe the short time you can pick up from scaling the vehicle at race trim with you in it. My cars breakdown is very close to yours with just a better 60ft. Gives you a great idea where you could be given the mph.
60ft 1.59
1/8th 6.78 at 105mph
1/4 10.29 at 141mph
60ft 1.59
1/4 10.29 at 141mph
60ft 1.59
1/4 10.29 at 141mph
60ft 1.59
1/4 10.29 at 141mph
A large part of it is driver too. Forgot to mention that. (seat time and knowing your car is the only cure)
slow shifts and boost falling off then trying to make it up with power up top will do it to ya!
PS: That 1/8 mile ET is :thumbs up:
makes my head hurt comparing your slip to his. lol
i know the car, nd seat time is there as well this is why i took my tuner to the track with me to ensure that it wasnt my driving he said it was that at all.
coming off 2 step at launch the rpm's were dropping way to much
i need an explanation of scaling the car?
You just need to find a shop that can corner balance your car. Get the car exactly how you would have it at the track and with you in it down to the fuel being where you would have it etc. The shop will put a scale under each one of your wheels. The scales will tell you how much weight is on each tire and your total weight. The idea is to spread the weight evenly onto your front tires to help with traction. We also moved a good bit of weight forward onto the front tires as well depending on the vehicles purpose. They will adjust the weight via your coilovers. Once its done, if your car has never been scaled I would expect nothing less then a tenth off your 60fts. Thats if everything else is in order. For the money most places will charge its well worth it.
i found scaling through google so im good lol
my last run
http://www.youtube.com/watch?v=6AsuPBprNcQ
my last run
my last run
my last run
Haha, EF love, heres mine.
http://www.youtube.com/watch?v=hP1KdqGlwt8
Sad part is this year I haven't made it back to the track because of my business. First year I have had a car setting freshly done and not get to race it. I haven't even started to play with the Ectune options yet, lol.
i was just watching your vids man the main differance i see if when you launch your power keeps growing mine seem to be steadly shitty lol you launch spins tires and go i launch and never hear the power really increase at all
How much boost or power are you running in first gear? Are you datalogging each pass?
I made 550 on 15psi and 630 on 23psi and here are my short track times. The car hasn't even seen 23psi at the track yet. This is launching at 6500rpm with no antilag setup it leaves the line building around 8psi.
60ft. 1.65
330 4.30
1/8 6.520 @ 114
boost by gear through hondata
15psi in first but timing is backed off a couple degrees to calm it down
19psi in second gear
21psi in third
Too much power can hurt especially on our cars. keep the power low at first. dial it in off the wastegate then start turning power up little by little.
60ft. 1.65
330 4.30
1/8 6.520 @ 114
21psi in third
light car and responsive sc61 FTW!!
In the first pass you were slow on the 1-2 shift and it was still in the powerband spinning.
