Take a look at my data log
Old Jun 29, 2011 | 10:18 PM
550whpcivic's Avatar
Default Take a look at my data log
Having boost problems or maybe it's my tune?. 1st only goes to 8psi, 2nd goes to 12psi then 3rd-4th goes to 15.7psi. Check all my vband clamps but couldn't find any loose. Need ways to get boost to jump to 15psi in all gears.
Let me know what you thing and I'm on pump gas and the first part of the log is the burnout
2.0lsvtec
s366 .91a/r
twinscroll topmount
Old Jun 30, 2011 | 12:40 AM
uglyasscivic's Avatar
Default Re: Take a look at my data log
please email cgracing1@gmail.com
I need more info.
Old Jun 30, 2011 | 01:26 AM
wolve's Avatar
first things i see is...
your not building a whole lot of boost off the line, in fact it looks like you're just starting to build boost when you launch. maybe give it some time to build boost at the line.
also you shifting quite slow whilst completely lifting. boost falls on it's face badly and needs to pick up all over again. learn to shift fast and install FTS so your boost picks up where it was the gear before.
that combined with building proper boost at the line should help alot, that's just driving. i don't know how much you can find in the tune?
Old Jun 30, 2011 | 09:50 AM
Thanks for the info, It was the first time out and I was just getting the feel for the car plus I was on nittos dr . I'm going to go buy a cruise control switch so I can hook up the full throttle shift and get that set up.
I was going to let it build about 10psi of boost but I didn't wanna blow the tires off but still did anyway. The way it pulls from a roll/3-4 gear is very nice with the s366. Maybe it's me but if I roll into the throttle in second it will go to 15psi? weird?????
2.0 lsvtec 84mm
twinscroll top mount
s366 t4 91ar
1200cc injectors
victor x manifold
gsr cams
Old Jun 30, 2011 | 03:41 PM
tofast4uh22's Avatar
its because of the lack of traction. if the tires are spinning it is not going to make full boost. there isnt enough load on the engine. the same theory is when sitting still and reving the engine does it get 15psi? no, cause there isnt enough load. so when your car finally hooks up fully in third gear it produces enough load to spin the turbo to the rpms it needs to make full boost.
Old Jun 30, 2011 | 03:56 PM
I'm barley spinning a past the lights lol. I guess I just need to shift faster
Old Jun 30, 2011 | 06:07 PM
CO_RaceFab's Avatar
I see little if any tire spin in this log
Old Jun 30, 2011 | 06:32 PM
bads2k's Avatar
Yeah there isn't much spin. That's not why boost isn't there in 1st and second. Have you checked for any boost leaks. Could be from just not leaving on boost in first and letting completely out on the 1-2 shift. It loses all boost between the 1-2 shift and drops quite a bit of rpm out of boost range
Old Jun 30, 2011 | 08:08 PM
It was the first time out in the new setup and I was just worried about breaking things lol. So with the fts and *****, I SHOULD run a good number
It's just werid that if I roll into the throttle in second it will full spool?
Old Jul 1, 2011 | 08:11 AM
guy_from_nerk's Avatar
You was hitting 15psi?
Old Jul 1, 2011 | 08:15 AM
I turned it up after the track on the way home but it wasn't working read my new call out thread lol on cr
RedlineMotive
Nov 6, 2010 10:38 PM
trigger_time
Aug 25, 2009 12:38 PM
crazyimport
Sep 1, 2005 06:16 PM
B16Civic93
Jul 13, 2005 02:12 PM
RTW DC2R
Apr 6, 2004 08:08 PM
