Stripped threads on block
Old Jun 12, 2009 | 06:35 PM
  #26
kenbdSi's Avatar
Default Re: Stripped threads on block
Not sure if anyone mention, but if you know anyone that can weld aluminum you can have the hole filled in and have a good machinist re-drill the block and resurface it as well. Timesert are good but are a little pricey.
Old Jun 15, 2009 | 07:51 AM
  #27
Golden Eagle's Avatar
Originally Posted by JJsMotorsports
I felt its was worth the extra money to avoid stud streching and all labor to replace studs and head gasket one day I may go more than 50psi.........???
for a piece of mind it don't heart but i don't see the need when like i said eggun ran the standard ones in the 7s I'm sure she was at 50psi or more with no problems
that is in no way something anyone should try ever. 1st it would be almost imposable to get weld that deep in the block if not imposable. 2nd that much heat on the block would defiantly warp your block and you would need to have it decked and line bored after if you did attempt it and sorry that would cost more then just having it fixed right the first time with a timesert. please do not post bad info like this its a wast of everyones time and can cost someone lots of money trying to do something thats not going to work
Old Jun 15, 2009 | 08:04 AM
  #28
Antilag's Avatar
I agree with Robert, Don't weld the block. Listen to a guy who works for one of the top machine/sleeve shops. Timecert the block or that particular hole, you will never have issues again.
Another question? Why did you switch from a ge head stud to a arp??
Old Jun 15, 2009 | 08:18 AM
  #29
newtype_33's Avatar
i used timesert works good....
hYbRid_Eg6
Jan 26, 2012 10:00 PM
DC2-ProdUcTiOnS
Oct 27, 2011 02:07 PM
horn12007
19
Sep 20, 2010 06:02 PM
EJ1_Can2
Sep 10, 2010 08:18 AM
kabaroo
10
May 21, 2005 10:41 AM
