Stock block Type R block
Old May 12, 2007 | 06:21 PM
1Quikgsr's Avatar
Default Stock block Type R block
first time out with the new power made 4 passes down the track here was the best one... 341whp 227 tq im still on the stock mounts i think i need to get some good mounts, this was with a full tank of gas and full interior.. 10psi full exhuast
r/t .171
60' 1.939
330 5.213
1/8 7.901
mph 93.80
1000 10.239
1/4 12.186
mph 116.89
jdm gsr motor
jdm itr pistons- 11.3 cp
sp manifold
skunk2 im
jdm itr tb
precision sc-61 turbo
3 inch dp
tial 38 mm wg
precision ic
aem fuel rail
aeromotive fpr
walbro fp
act hd clutch
ctr camshaft
rc 550 cc injectors
hondata s300
Modified by 1Quikgsr at 9:34 AM 5/21/2007
Old May 12, 2007 | 08:45 PM
Rogue108's Avatar
Default Re: Stock block Type R block (1Quikgsr)
So nice and shiny clean...
Old May 13, 2007 | 04:37 AM
DRAGLS's Avatar
Default Re: Stock block Type R block (Rogue108)
I did not see it mentioned, slicks? dr? street?
Old May 13, 2007 | 07:38 AM
Rage Cayman's Avatar
Default Re: Stock block Type R block (DRAGLS)
Clean looking ride
Old May 13, 2007 | 07:44 AM
simply's Avatar
you use those same pictures for everything.
Old May 13, 2007 | 08:05 AM
nsxmatt's Avatar
Figured you would trap higher than 116 with 350whp.
Old May 13, 2007 | 11:13 AM
1Quikgsr's Avatar
it was on 23.5 slicks
Old May 13, 2007 | 02:03 PM
A.E Motoring's Avatar
a lil more seat time will get u lower 12s i went 11.9-12.0 with 306 and 220, good time
Old May 13, 2007 | 02:16 PM
taggart_lumpy's Avatar
Old May 13, 2007 | 02:47 PM
1Quikgsr's Avatar
Default Re: Stock block Type R block (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">a lil more seat time will get u lower 12s i went 11.9-12.0 with 306 and 220, good time </TD></TR></TABLE>
yes i plan on upgrading the mounts and getting more seat time in... what was your trap BTW&gt;
Old May 14, 2007 | 04:21 AM
most_hated_crx's Avatar
CLEAN AS A MOTHAFUCKA
Old May 14, 2007 | 04:25 AM
93supercoupe's Avatar
Default Re: Stock block Type R block (most_hated_crx)
lets see some other pics.
Nice car and with more seat time u should hit high 11's.
Old May 14, 2007 | 11:30 AM
Group Tenacity's Avatar
you might want to change the location of your catch can, having it mounted sideways like that will cause you to get oil everywhere...
you should mount it with the filter upright so it wont leak when it gets full...
pretty clean otherwise...
Old May 14, 2007 | 01:35 PM
1Quikgsr's Avatar
Default Re: Stock block Type R block (Group Tenacity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">you might want to change the location of your catch can, having it mounted sideways like that will cause you to get oil everywhere...
i have a baffle in there it does not spill oil thanks though
Old May 15, 2007 | 12:57 AM
rite on...
Old May 15, 2007 | 04:49 AM
RTW DC2R's Avatar
very clean
Old May 15, 2007 | 09:23 AM
EATIN UP UR BSERIES's Avatar
car looks good..
Old May 15, 2007 | 01:36 PM
hybridEj6's Avatar
Default Re: (EATIN UP UR BSERIES)
nice...your set up is very similar to mine just a different turbo
Old May 15, 2007 | 01:43 PM
BoostedJeff's Avatar
Default Re: (hybridEj6)
get some seat time and some bigger tires art!!!
Old May 15, 2007 | 03:57 PM
1Quikgsr's Avatar
Default Re: (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">get some seat time and some bigger tires art!!!</TD></TR></TABLE>
will do jeff ill be out there on wednesday getting more runs in... hey did you get your setup done yet???
Old May 21, 2007 | 12:31 AM
1Quikgsr's Avatar
i fergot i made a topic earlier
v1sion
Feb 10, 2011 05:03 PM
1Quikgsr
Jun 12, 2007 01:17 PM
1Quikgsr
May 10, 2007 03:49 PM
1Quikgsr
Apr 25, 2007 07:13 AM
0554
Jul 18, 2006 03:51 PM
