stall converter?'s
Old Jul 26, 2002 | 08:30 AM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default stall converter?'s
ok, a couple of fairly quick questions.
1.how does it work exactly?I know it allows the rev. to go up to a certan point for launch, but just wondered how it worked.
2. what kind of stress does it expell on the engine,tranny,drivetrain?
thanks, M
I'm goin to lunch whoohoo!!!
Old Jul 26, 2002 | 09:54 AM
littlebluecrx's Avatar
Default Re: stall converter?'s (sleeperaccordv6)
All auto matics have a torque converter, changing the stall rpm can fine tune the car's launch, if you have a turbo car a higher stall would be required, if you had a nitrous car it would be lower, weight slick size final drive all sort's off detail's that would be taken into account to choose the right stall speed.as far as how a converter works, it is sorta of like a centrifical clutch, that does not lock up until a certian rpm or "stall speed".It is very easy on the engine and drivetrain compared to manual transmision's, but has more power loss due too the converter and automatic.Jason
Old Jul 29, 2002 | 09:45 PM
jk94z28's Avatar
High stall torque converters generate lots of transmission heat but if you get a trans cooler you should be alright.
salaamq
Apr 18, 2012 04:48 PM
beatthisspeed69
Jul 15, 2006 08:41 PM
rotflmao
Jun 6, 2005 11:18 AM
RR98ITR
Mar 31, 2003 11:49 AM
Integra187
Jul 16, 2001 07:09 PM
