Staging brake problems
Old Mar 20, 2009 | 09:14 PM
MkIIRoc's Avatar
Default Staging brake problems
Tried searching, but didn't find the answers I was looking for.
I installed a CNC hand brake running the rear brakes. It's the 3/4" master cylinder version. Line runs out the back to a wilwood 10psi residual valve to a split, to the rear wheels. Fully bled. (Had the same problem before I installed the valve, so it's not that. Put it in since the factory valve is under the hood)
Problem is the handle moves about 1/4" and then is rock hard, but I can't hold the car still for crap! Anyone else run into this issue? Too large of a master cylinder possibly? They have a 5/8" version as well.
Unless I'm supposed to pull the handle to the point it feels like I'm going to rip the brake off the floor, something isn't right. Thanks for any help!
Old Mar 20, 2009 | 10:27 PM
jdmdc529's Avatar
Default Re: Staging brake problems
You described the same exact problem i have as well. lol
Old Mar 21, 2009 | 03:06 AM
DaveF's Avatar
i have this staging brake which is hooked up completly by itself. the hose runs through the floor, into a line lock, then to a T, then to both brake calipers. i have no problems holding the car. simply pull the brake, hit the line lock, let go of the lever, and do your thing.
Old Mar 21, 2009 | 07:08 AM
MkIIRoc's Avatar
What size master cylinder are you running? 5/8 or 3/4"? Looks a little smaller diameter then mine, so i'm going to guess 5/8".
So it's sounding more and more like just too big of a master cylinder.
Old Mar 21, 2009 | 07:36 AM
Sir2egk's Avatar
http://www.kenskustomchassis.com/Staging_Brakes.htm
Old Mar 21, 2009 | 08:08 AM
MkIIRoc's Avatar
Ok, that link doesn't really help. I can post links too That looks like a CNC brakes hand brake, which is what I already have.
http://www.cbperformance.com/catalog.asp?ProductID=934
I'm trying to figure out if I should buy a new master cylinder for mine or if someone else has had this problem and it was something different.
Old Mar 21, 2009 | 10:32 AM
HotRodCarrillo's Avatar
I have mine set up the same way as DaveF And it works just fine i would try Changeing my setup
Old Mar 21, 2009 | 11:01 AM
jjspec's Avatar
Try to take the residual valve out and see what happens.
Old Mar 21, 2009 | 11:14 AM
DaveF's Avatar
i just looked for a number on my brake, and couldnt see one ?
Old Mar 21, 2009 | 11:35 AM
MkIIRoc's Avatar
The first post says I had the problem before I put the valve in.
Dave- That's cool, thanks for looking. A new master cylinder is only $50 or so, worth a shot.
Old Mar 21, 2009 | 03:08 PM
jjspec's Avatar
Sorry, reading owns me sometimes, lol!
Old Mar 21, 2009 | 03:30 PM
jdmdc529's Avatar
I have mine hooked up the same exact way minus the line lock. Do you think that could cause me not to be able to hold the car?
Old Mar 21, 2009 | 04:05 PM
DaveF's Avatar
does the brake hold the car when you hold the handle back ? the only thing the line lock does is hold the pressure in the line, so you dont need to hold the handle.
Old Mar 21, 2009 | 04:45 PM
jdmdc529's Avatar
No sir it wont. Even with both hands trying to pull it back i can even get them to hold. I can get the handle to move back a little more than MkIIRoc, but then feels rock solid.
Old Mar 21, 2009 | 04:50 PM
DaveF's Avatar
did you run your own lines to the rear calipers ?
Old Mar 21, 2009 | 04:56 PM
MkIIRoc's Avatar
Haha, me too.
I ordered a smaller master cylinder, "wheel" see how it works
Old Mar 21, 2009 | 05:36 PM
jdmdc529's Avatar
I ran my own to braided hose to a tee then to each of the factory hardline
Old Mar 21, 2009 | 06:28 PM
DaveF's Avatar
are your brake pads shot ? can you take the wheels off the car, and have a friend see if the calipers/pads are moving when you pull the handle.
Old Mar 21, 2009 | 06:50 PM
jjspec's Avatar
Could be the caliper slide pins sticking also.
Old Mar 25, 2009 | 06:52 PM
alonsobuiltmotors's Avatar
this has prolly been brought up too many times but i cant seem to find what i need in the search.. i oredered my staging brake today and i was on the phone with a chassis builder that said to unhook the rear brakes from the foot master and run new lines from the hand master to the rear calipers. then only have front brakes on the foot master is ths true? and what size lines am i goin to need
Old Mar 25, 2009 | 10:05 PM
i got the answer thanks anyway
Old Apr 3, 2009 | 08:13 AM
jdmdc529's Avatar
I put a new caliper on one side and a set of hawk pads and i can lock them up now. Thanks for you help.
Old Apr 4, 2009 | 09:25 PM
boost4life's Avatar
car you run a staging brake and still have the foot master cylinder function in the rear?
Old Apr 5, 2009 | 03:17 AM
DaveF's Avatar
good to hear ! keep us updated on your progress, and post some new pictures of that beast !!
yes, that can work, but it would require an inline style staging brake, along with an adjustable style proportioning valve. personally i dont like the idea of the rear wheels getting any kind of braking pressure, especially on skinnies, and if you really gotta get on the pedal to slow the car down. seems like you are just headed for disaster. i belive it was SixSigmaRacing (danny tran) in his allmotor RSX who had a slight mishap with his rear wheels locking up with a similar style brake setup.
Old Apr 5, 2009 | 11:17 AM
jdmdc529's Avatar
[quote=DaveF;38044838]good to hear ! keep us updated on your progress, and post some new pictures of that beast !!
haha i deff. will. I just got back from PBIR and the stage brake felt great. Fastest pass is in my updated sig
Specail Ed
Suspension & Brakes
Jun 24, 2019 07:40 AM
rockrig
Nov 21, 2011 02:01 AM
jdmswappedcivic
Suspension & Brakes
Apr 18, 2010 09:30 PM
bonspeed
Dec 20, 2009 12:34 PM
C2Imports
Oct 6, 2004 08:50 PM
