Staging Brake
Old Nov 17, 2004 | 04:27 PM
LSR-Abuser's Avatar
Default Staging Brake
Any of you guys out there using a staging brake?
would like to know some for info on them like
1.Setup
2.instailtion
3.performance.
GETTING TIRED OF USING THE E BRAKE.
Old Nov 17, 2004 | 04:40 PM
Kataku2K3's Avatar
Default Re: Staging Brake (LSR-Abuser)
Just curious but are you planning on using one on a race or street car? Takes a bungee cord to make it an E-brake as it won't stay locked.
Old Nov 17, 2004 | 04:41 PM
eddiecut's Avatar
Default Re: Staging Brake (Kataku2K3)
haha good one adam, i wouldnt use a staging break on a street car, unless its 95% race and 5% street
Old Nov 17, 2004 | 04:44 PM
LSR-Abuser's Avatar
Default Re: Staging Brake (eddiecut)
lol NOOOOOO
RACE CAR ONLY
Old Nov 17, 2004 | 04:49 PM
Kataku2K3's Avatar
haha okay cool just checking. They're pretty basic to setup. First off you'll have to cap your stock brake lines running to the rear. Mount the staging brake itself wherever it fits and for what is comfortable. Then you just need to run a line to the rear and T it into each brake. Simple as that and they do work well.
Old Nov 17, 2004 | 04:52 PM
LSR-Abuser's Avatar
Sounds pretty basic! got any pics from inside the car Bud?
There really tall right?
Old Nov 17, 2004 | 04:56 PM
Kataku2K3's Avatar
I do have some pics but they're actually not on this computer so I can't load them up right now. I'll PM them to you just as soon as I do tho and yea, they are pretty tall.
Old Nov 17, 2004 | 04:58 PM
LSR-Abuser's Avatar
NICE Thanks Bro
Old Nov 17, 2004 | 07:14 PM
Project-D's Avatar
How much pressure does the stage break have? 150-200psi? I know it is not lots like a regular system.
Old Nov 17, 2004 | 07:18 PM
tony1's Avatar
Default Re: (Project-D)
The cylinder diamter will determine how much pressure it will make with a given effort. It's a normal master cylinder, it'll make plenty of pressure. I know for a fact you can make over 1000psi...
Old Nov 18, 2004 | 01:52 PM
msmotorsports's Avatar
Can't you make the staging brake run inline with the stock lines so you can still use the rear brakes while slowing down after a run?
Old Nov 18, 2004 | 01:55 PM
paulzy's Avatar
Default Re: Staging Brake (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Can't you make the staging brake run inline with the stock lines so you can still use the rear brakes while slowing down after a run?</TD></TR></TABLE>
Old Nov 18, 2004 | 02:08 PM
Kataku2K3's Avatar
Default Re: Staging Brake (paul vang)
Maybe there's a way, never done it that way tho using some kind of check valve? I'm sure Tony would know for sure!
Old Nov 18, 2004 | 02:58 PM
LS_REX's Avatar
That staging brake is designed to run inline, since it has no fluid reservoir.
Its kind of difficult to attach one of these to a tandem brake system. You would have to tee both rear brake lines together coming out of the proportioning valve, run that line into the brake, then tee them back out to each rear brake line. This works but it kinda makes the tandem brake system useless.
BTW I have one of these for sale, used only about a month.... I'll take $80 shipped
Rob
Old Nov 18, 2004 | 03:03 PM
Kataku2K3's Avatar
Default Re: Staging Brake (LS_REX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS_REX &raquo;</TD></TR><TR><TD CLASS="quote">
That staging brake is designed to run inline, since it has no fluid reservoir.</TD></TR></TABLE>
Damn, I didn't even notice that.
Old Nov 18, 2004 | 03:06 PM
LS_REX's Avatar
Oh, I have seen one of these used to control a seperated rear braking system...they just used a small reservoir on the suction side of the cylinder.
Old Nov 18, 2004 | 06:39 PM
Zubaltec's Avatar
We are using one on our Turbo 4 car.
I made all new stainless brake lines for the whole system. There are 2 ports on the master cyl. Use one for the front brakes (T'ed to each side). Use the other to run to a prop. valve then to the staging brake then T'ed to each side in the rear. Get a Autometer gauge and put it after the staging so you know how much psi you can drag in to lights and stage. It takes some getting use to.
John
Old Nov 18, 2004 | 07:08 PM
fast is fun's Avatar
thats what it has do to be nhra legal <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Can't you make the staging brake run inline with the stock lines so you can still use the rear brakes while slowing down after a run?</TD></TR></TABLE>
Old Nov 19, 2004 | 06:13 AM
Zubaltec's Avatar
Default Re: Staging Brake (fast is fun)
I don't believe a staging brake is legal for NHRA SFWD. It's been discussed before.
John
Old Nov 19, 2004 | 06:29 AM
ProfessorNate's Avatar
Default Re: Staging Brake (Zubaltec)
This is right from CNC's website. It's reversed for RWD cars, since obviously then need it the other way.
Here's one place to get them....
http://www.cbperformance.com/c...D=933
Some of you street car guys may want to run he horizontal handle type, so you don't have a big lever sticking up in the middle of the car.
Old Nov 19, 2004 | 07:19 AM
regamaster's Avatar
Default Re: Staging Brake (ProfessorNate)
This looks like a RWD configuration?
The problem that I have seen, is that tying into the brake pedal like that will cause the front end to dive and the rear tires lock up since the weight is being lifted off of the rear due to braking. Sometimes even popping the tire and causing a crash. There have been some talk that NHRA was suppose to clear up the rule on the way this is connected.
Old Nov 19, 2004 | 07:53 AM
Default Re: Staging Brake (regamaster)
use a proportioning valve<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regamaster &raquo;</TD></TR><TR><TD CLASS="quote">This looks like a RWD configuration?
The problem that I have seen, is that tying into the brake pedal like that will cause the front end to dive and the rear tires lock up since the weight is being lifted off of the rear due to braking. Sometimes even popping the tire and causing a crash. There have been some talk that NHRA was suppose to clear up the rule on the way this is connected. </TD></TR></TABLE>
rogueeg6
May 10, 2011 10:56 PM
GT30EK
Jan 9, 2010 02:59 PM
alonsobuiltmotors
Feb 12, 2009 05:56 PM
logg_frogg
Mar 8, 2008 02:58 PM
servion
Feb 26, 2004 05:07 PM
