Spool VS LSD
Old Jul 8, 2008 | 01:16 PM
xtremvw's Avatar
Default Spool VS LSD
im running a lsd right now in my VW running 10.5@144mph i know the spool locks both wheels and would be better but safety wise, if a axle snaps your right in the wall??
is it really worth it 1/4 mile time to run a spool VS the chance to wreck the car or even worse go into the next lane and god knows what would happen
Thanks
Old Jul 8, 2008 | 01:30 PM
cotorresgee's Avatar
Default Re: Spool VS LSD (xtremvw)
I have broken axles with a spool and it is not that bad...the car does not pull hard from my experience just feels like it has no momentum
Old Jul 8, 2008 | 01:52 PM
jdm inc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">If your LSD is working and holding up don't change a thing.</TD></TR></TABLE>
Old Jul 8, 2008 | 02:53 PM
1992Si's Avatar
Default Re: Spool VS LSD (jdm inc)
It's not fun pushing a car with a spool.
Like rota said, Keep what you got as long as it holds.
Old Jul 8, 2008 | 04:49 PM
Whitesleeper's Avatar
I've had both (circuit worx spool and now a kaaz diff) and i cant tell the differance at the track and my 60 fts are almost identical (1.65s). Of course it is a lot easier on the street with the kaaz.
Old Jul 8, 2008 | 07:17 PM
1FSTHATCH's Avatar
I've ran both a personally like the LSD. The spools are nice but its crazy trying to turn the car with slicks on. If that doesn't bother you then go either way. again, i wouldn't fix something that isn't broke either..
Old Jul 8, 2008 | 07:23 PM
SPOOLINmatt's Avatar
Default Re: (1FSTHATCH)
i snapped an axle right off the line with my quaife once and headed strait for the concrete divider where the tree was located, it was a wild ride. Its only done that once, my friends were like OH ****!!
Old Jul 8, 2008 | 07:39 PM
Default Re: (rota92)
well i wasn't quite ready for it, it just jerked like hell, i had never experienced that from my drive train.
Old Jul 8, 2008 | 07:55 PM
2fastGSR's Avatar
King of the One Liners
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">i snapped an axle right off the line with my quaife once and headed strait for the concrete divider where the tree was located, it was a wild ride. Its only done that once, my friends were like OH ****!!</TD></TR></TABLE>
Huh thats interesting.
I have snapped more axles than i care to admit right off the line and my car just came to a dead stop. Barely even broke the beams . . .
Old Jul 8, 2008 | 09:21 PM
Boner_Ben's Avatar
Default Re: (2fastGSR)
I've had some very scary times with a spool, I'd definitly reccomend getting an LSD. Even just for the sake of pushing the car an LSD is worth the extra money.
Old Jul 9, 2008 | 04:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">
I have snapped more axles than i care to admit right off the line and my car just came to a dead stop. Barely even broke the beams . . .</TD></TR></TABLE>
ive broke 3 in 4 years or so. 2 were just clean snaps, i think this one just broke really wierd and was just not breaking clean, it did it all inside the boot and i never took it apart to see how it broke.
Old Jul 9, 2008 | 09:34 PM
1FSTHATCH's Avatar
On a spool though its a different story. All the power is going to go straight to the other side that is still intact. Thats where alot of the people comment that they head for walls going down the track. In most cases the axle is going to snap inside the 330 but its not to say it cant happen anywhere on the track. If you get off the throttle in time there isn't much to worry but if you stay into it your going for a ride . Where on a LSD when the diff breaks most cases it just free revs the motor.
Old Jul 10, 2008 | 04:36 AM
ALL IMPORT's Avatar
i would have to believe a spool would cut a 60ft better just cause a my quaif seems to let 1 tire spin for split second. thus causing both tires being more prone 2 breaking loose.
& spool should b a dead even hook as long as your loading down on the trans.
correct me if i am wrong but thats how i look at it
American.Graffiti
May 28, 2008 08:01 PM
deathofadam
30
Jun 15, 2007 05:13 AM
clemsoncb7
Apr 2, 2007 07:46 AM
AznBlueBoy
Jun 22, 2006 02:44 PM
9seccivicsi
Aug 25, 2004 06:55 AM
