Some trans ?s
Old Aug 31, 2010 | 03:29 PM
b00stgetsUlaid's Avatar
Default Some trans ?s
Hey guys im currently starting my new buildup...I am wondering want kind of transmission set up will be best suited for me gear wise and whatnot...its going to be a eg hatch with a ls/vtech big turbo with between 700 and 900whp...before i had the motor in a crx making 550whp with a cable ls trans with no lsd still running 10.1s...thanks for the input guys!
Mike
Old Aug 31, 2010 | 03:30 PM
Default Re: Some trans ?s
Also what clutch should I run?
Old Aug 31, 2010 | 04:04 PM
Ls_dx's Avatar
Heres what I do. Use what you have, or can get for the cheapest/easiest.
With that much power you should get a twin disk.
Old Aug 31, 2010 | 04:07 PM
c5R's Avatar
c5R
what is your budget the 700-900hp range requires a driveline setup the is as much as or more than the value of your engine
Old Aug 31, 2010 | 04:29 PM
right now its up in the air...im just looking at what my options are and what would be the most effective without going way overboard...i was thinking of using a ls hydro trans and maybe changing the gearing up a little and throw a lsd in it...what brand clutch is recomended?
Mike
Old Aug 31, 2010 | 04:34 PM
c5R's Avatar
c5R
tilton is my clutch of choice.
Old Aug 31, 2010 | 04:37 PM
85mmek9's Avatar
I run the competition clutch twin and love it. If you have the money but it right the first time, buy a dog box, ppg, liberty, gforce, at least some 5.9s axles.
Old Aug 31, 2010 | 04:38 PM
YZFR6's Avatar
x2 on Tilton and save your money... Do it once buy PPG, I learned my lesson already. Lol...
Old Aug 31, 2010 | 04:42 PM
85mmek9's Avatar
And while your at it you might as well pick you up a gforce T1 shifter lol
Old Aug 31, 2010 | 05:08 PM
PuroMotor's Avatar
Or become a really good driver and run stock transmissions on 750hp+ cars like the Puerto Ricans do. If not.. Twin Disk, dog box, 5.9s done deal, happy racing.
Old Aug 31, 2010 | 05:09 PM
anyone have problems with ppg...i have a ppg dogbox in my wrx and i love it but i did have issues with it breaking when i first got it in less then 5000 miles...its been ok since its been rebuilt knock on wood
Old Aug 31, 2010 | 05:16 PM
PuroMotor's Avatar
With those boxes you really have to do something bad to break it. Like going from 3 to 1 or something like that.
Old Aug 31, 2010 | 05:18 PM
wheres a goood place to buy the ppg from? what do they typically range for hondas...pretty new to the honda game
c5R's Avatar
c5R
+1 on the T1 gforce shifter i bought the regular gforce shifter and i hated it had to do lots of work to make it woke its not a bolt in deal like the t1 modified shifter is
Old Aug 31, 2010 | 05:20 PM
PuroMotor's Avatar
T1.... 4 to 6 k
Old Aug 31, 2010 | 07:14 PM
tmar253's Avatar
Albins has a dog set that is currently being tested. I know one car that is using it just went 8.92 @ 179.31 at the West Coast Shootout. If you plan on driving the car on the street at all I would checkout Albins Honda B Series Synchro Engagement Helical Gear Set which has been out for a while now. Also if you plan on going with the dog box you may look into getting an aftermarket bellhousing by nrg tech or liberty. Hopefully the people that are using this gearset will chime in. Good luck
Old Sep 1, 2010 | 09:38 AM
str8JDMteggy's Avatar
Buy a gear set or replace stock trannys every 2 runs
Old Sep 1, 2010 | 07:38 PM
runsfromdacops's Avatar
Albins gears set all the way.
street/strip car = Albins syncro set
track **** = Albins dog set
dont wast your $$$ on the 3 letter sets
-alex
Old Sep 1, 2010 | 07:49 PM
Mr. Em1's Avatar
the driveline is going to cost more than you motor
PPG's, g force shifter Dss pro level setup! call it a day
Old Sep 1, 2010 | 08:44 PM
IT'S ME DAVID's Avatar
NooB
-alex
Where can i find these sets @ please pm me.
Old Sep 1, 2010 | 10:09 PM
fixed
Old Sep 1, 2010 | 10:32 PM
BubsBoostedEG's Avatar
if ur on a budjet treat some stock gears and get a twin mine held up to about 60 passes with no issues power ranging from750-850whp and 10.1-9.5at 150-159mph in a 2400lb car
Old Sep 2, 2010 | 06:50 AM
tmar253's Avatar
-alex
X2
Old Sep 2, 2010 | 07:19 AM
SPOOLINmatt's Avatar
liberty is still a great box as well.
Joshb152
Transmission & Drivetrain
Dec 27, 2015 01:32 PM
That_DA_guy
Sep 27, 2015 07:19 PM
EvilWuzzle
May 17, 2010 05:53 AM
1SiC 3DR
Sep 1, 2006 02:21 PM
Jonathan_ED3
Mar 13, 2002 02:10 PM
