Some advice on cams
Old Sep 26, 2007 | 05:48 PM
Monkeyballs's Avatar
Default Some advice on cams
I have read many good reviews on using the Skunk2 Pro1's in a high boost B-series seup. But I as wondering if anyone is using or has tried the Pro2's. I can get them pretty easy, but didn't know how they would be in my application. I am running a fully built 2L LS/Vtec with a 42r.
Old Sep 26, 2007 | 05:51 PM
miller's Avatar
Default Re: Some advice on cams (Monkeyballs)
how do you k now if the pro 1's will even work with your setup?
Innes's Avatar
Default Re: Some advice on cams (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">how do you k now if the pro 1's will even work with your setup?</TD></TR></TABLE>
because tony1 said so
Old Sep 26, 2007 | 05:56 PM
miller's Avatar
Default Re: Some advice on cams (Innes)
lmao, i was waiting for someone to say that.
To the original poster, just because they worked on one application does not mean that they will work with yours.
Old Sep 26, 2007 | 06:20 PM
I don't know that they would work for sure. I made 733hp on itr cams. and figure I would give something different a shot. I have seen more than Tony use Pro1's with good results and I have a friend with a set of Pro2's. I was just wondering if anyone had used them with good results.
Old Sep 26, 2007 | 06:24 PM
mikesrex's Avatar
we use all motor cams on turbo cars all the time with great results.
try it out and see how you like it.
Old Sep 27, 2007 | 12:57 PM
Default Re: (mikesrex)
I may but I don't want to buy them to find out they wont work well.
Old Sep 27, 2007 | 01:04 PM
Innes's Avatar
Default Re: (Monkeyballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Monkeyballs &raquo;</TD></TR><TR><TD CLASS="quote">I may but I don't want to buy them to find out they wont work well.</TD></TR></TABLE>
buying them and trying them is the only way you are going to be able to answer your own question of whether or not they will work well for your setup
DarkSolPR
May 6, 2005 10:42 AM
escape2me
Mar 6, 2005 08:54 PM
junoroadcone
Jan 27, 2005 12:07 PM
SloazzEKhatch
12
May 10, 2004 03:01 AM
projectTeG
22
Oct 24, 2003 03:15 PM
