Solid Rear Axle....
Old Oct 16, 2002 | 09:30 AM
BoostinDC2's Avatar
Default Solid Rear Axle....
Does anyone know who makes a solid rear that doesnt make you cut the rear sub frame out?
Old Oct 16, 2002 | 11:14 AM
ExospeedAMcrx's Avatar
Default Re: Solid Rear Axle.... (BoostinDC2)
Elite Motorsports? is that the kind you are looking for jerry?
Wil
Old Oct 16, 2002 | 12:48 PM
BoostinDC2's Avatar
Default Re: Solid Rear Axle.... (exospeedAMcrx)
wil-
im just trying to find out which one allows you to keep the rear subframe in place cause i have lots of racer's calling and asking me if they can run a solid rear in all motor class but i dont know which one to recomend cause i know some of the kits out there are illegal in our series. but does elite motorsports have a website?
thanks
Jerry
Old Oct 16, 2002 | 04:49 PM
Jared's Avatar
http://www.mmrusa.com
Old Oct 16, 2002 | 07:07 PM
paulzy's Avatar
Default Re: Solid Rear Axle.... (Jared)
you think that solid rear axle would be ok to drive around?
Old Oct 16, 2002 | 07:45 PM
ninesecrx's Avatar
Default Re: Solid Rear Axle.... (paul_vang)
No...it gives you no toe in or out. also its not indipendent so if one shock hits a bump...the other goes bump bump as well. Like it says...its solid. Its a good easy way to take out weight but takes out drivability in a car...even look at Stephs tube cars, they dont even use a solid rear axle.
Old Oct 16, 2002 | 08:33 PM
crx12's Avatar
Default Re: Solid Rear Axle.... (ninesecrx)
I have an 86 crx that has a stock rear axle and I want it out. It's pretty heavy. I assume your talking about a hatch though.
Old Oct 16, 2002 | 10:34 PM
jerry,
well Bisi uses the Elite rear end. and it mounts to the stock mounting points. Uses a 1-2lbs caliper, and lightweight rotors(motorcyle rotors I believe). available in aluminum and mild steel. theres an adjustable tensioner thing that puts pressure on the whole thing also but i dont know how the details on that.( i guess acts like a wheelie bar)
Uses a spindle mount wheel which is provided with the kit.
the kit is about $2200-2500 depending on the type of wheel and material you choose.
Old Oct 17, 2002 | 02:59 AM
AussieK24's Avatar
I run a solid rear axle on my daily driven Civic. I'm running leaf springs in the rear. I have done a few autocrosses with this setup and there is NO problem with drivability/handling. It is the same rear setup that Domestic cars have been running for YEARS. The entire rear end (including single leaf springs, beam axle, hubs, shocks) weighs less than 24 lbs!!!! Dropped my times from 14.3 to 14.1 with no other mods!!
Old Oct 17, 2002 | 06:20 AM
newspeedR's Avatar
Here are pics of Elite (Randy's) solid rear axle...
looks simiar to the ground control/ advance design setup...
Old Oct 17, 2002 | 12:23 PM
MikeMAN's Avatar
Default Re: Solid Rear Axle.... (newspeedR)
how much weight does that thing remove?
Old Oct 18, 2002 | 05:40 PM
fortynineR's Avatar
Default Re: Solid Rear Axle.... (blemoine02)
anyone know the price or website on the nuformz?..
Old Oct 18, 2002 | 06:30 PM
HondaSpeedDemon's Avatar
the nuformz kit is 5 grand with the prostock rims.....
Old Oct 18, 2002 | 08:38 PM
ninesecrx's Avatar
You can t buy the nuformz kit direct from them...you have to buy it from a dealor. If anyone wants the kit, my price on it is $4000 without the wheels.
Old Oct 18, 2002 | 11:28 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
I paid $1485.00 for my MMR rear solid axle shipped. Includes rear solid axle, wilwood calipers, I think it's hal rear disc brakes with studs, etc...
SHould be here this week. Takes 2-3 weeks to make its custom made.
They say the MMR one removes 88lb's. we wil see actually how much it does when it gets here.
[Modified by Civicdrgrcr, 3:30 AM 10/19/2002]
[Modified by Civicdrgrcr, 3:33 AM 10/19/2002]
Old Oct 18, 2002 | 11:29 PM
Default Re: Solid Rear Axle.... (Civicdrgrcr)
QUESTIONS TO HOT ROD/QUICK CLASS RACERS!
Let me know if I am correct.
Solid Axle allowed in Hot Rod<-- Im correct right
Solid axle also allowed in Quick Class<-- Correct as well or was my friend correct about IDRC not letting you run Solid axle in Quick Class?
Thankz.
Old Oct 22, 2002 | 07:07 AM
SiREF8's Avatar
Who knows of a Dealer who sells the Elite Motorsports rear axle, and doe's Elite have a website?
Old Oct 22, 2002 | 09:13 AM
BoostinDC2's Avatar
for the IDRC Quick class we do allow solid rear just make sure you get a kit that doesnt make you cut the rear sub out.
If any of you guys have questions email me at jerry@importdrag.com
Thanks
Jerry Hsien
Technical Director @ IDRC
Old Oct 22, 2002 | 09:48 AM
I was getting ready to cut mine out. when you say rear sub frame the middle part where the trailing arms connect we are not allow to cut that out?
Old Oct 22, 2002 | 09:49 AM
BoostinDC2's Avatar
yes do not cut that out. once you cut the sub you are considered back half in our rules and thats a +100 pound penalty
Old Oct 22, 2002 | 11:37 AM
but I can use rear solid axle still. I think rules should be stated clearly in the IDRC rulebook. Almost cut it out and I would of been screwed $1500 down the drain.
Old Oct 22, 2002 | 04:29 PM
BoostinDC2's Avatar
yes you can run a solid rear just make sure you dont cut any of the rear sub out. if you cut any of the rear sub you take on a 100 pound penalty.
Old Oct 22, 2002 | 09:47 PM
In my opinion, DO NOT cut anything out of the floor, suspension points since all the rules are changing so often. Its not worth it and can bump you off a class you want to race at or the weight penalty.
Old Oct 23, 2002 | 04:24 AM
Question. If I did cut it out would I still be able to run in quick class with 100lb weight penalty. <--Means 100lb heavier or lighter?
Old Oct 23, 2002 | 08:33 AM
BoostinDC2's Avatar
yes, you would be able to run quick class but with a +100 pounds added to the car
and wil did you get my email?
[Modified by BoostinDC2, 9:34 AM 10/23/2002]
