Solid mounts/Loctite question? Lol.
I am actually curious/paranoid about this....
But has anyone had any problems like tensioner bolts/oil pump bolts backing out by switching to solid mounts?
Thanks.
Thanks.
I have innovative 85a's and they rattle bolts loose all the time. I just went through on wednesday and re-tightened every suspension bolt 90% of them were loose. I have had the 3 bolts that hold rear motor mount come loose so many times that I finally lock-tited the bolts, same with intermediate shaft bolts.
ive had a couple bolts back out on me, solid mounts, h22, no balance shafts.
off topic but didnt want to make a thread about it...
odd question, but do you need engine grounds with solid engine mounts??? i am just curious, i am running all my grounds. it seems as if you can get away without running grounds to the motor other than the thermostat ground
FWIW, I'm not a big fan of loctite. When you need to remove that item, it can be a pita.
I have found oil pan bolts lose on a normally mounted engine.
It's also a good idea to check all the bolts every now and then when you run solid mounts.
When we were running the car I would go over all the nuts and bolts before the weekend. I find it's best to do that when your all alone, no one to bother you.
I was very suprised whhen I switched to avid solid mounts, they were not much different in cabin vibration wise than the avid inserted alum mounts I removed.
So far nothing has vibrated loose, but we will see, I have only had them for 250 miles.
BlueRex1020
Aug 14, 2009 04:19 AM
JDMNICA
Jun 2, 2009 04:11 PM
digital sol
Jul 23, 2008 10:30 AM
