solid motor mounts?
Old Jan 19, 2007 | 03:31 PM
jwyndsdime's Avatar
Default solid motor mounts?
anyone know of a place where I can buy solid motor mounts for a 95 prelude?
(I've searched and found nothing)
Old Jan 19, 2007 | 03:40 PM
jdmoutlaw's Avatar
Default Re: solid motor mounts? (jwyndsdime)
You are going to have to make the or have them made by a fab shop
Old Jan 19, 2007 | 03:52 PM
jeffsciv23's Avatar
you can always fill them with 94a liquid poly, pretty damn close to solid and only costs about $30.
Old Jan 19, 2007 | 04:58 PM
accordking's Avatar
I'm making my own. i would recommend the same for you. We have odd ball vehicles to begin with.
Old Jan 19, 2007 | 05:05 PM
Blueprint's Avatar
camp1320 has mount kits with 85a urethane which is very stiff and will absorb some vibration... for the 95 prelude
Old Jan 19, 2007 | 09:05 PM
raceACCORDingly's Avatar
homemade...
Old Jan 20, 2007 | 07:46 AM
jwyndsdime's Avatar
ok thanks for the info guys!
Old Jan 20, 2007 | 01:13 PM
clemsoncb7's Avatar
Default Re: (jwyndsdime)
innovativemounts.com
Max
Old Jan 21, 2007 | 11:04 AM
fmfkid250's Avatar
I took a few plates of steel and did it in an hour... and less than $10...i left the center in place cut a hole in a plate and welded away!
Old Jan 21, 2007 | 11:31 AM
OnlyHJC's Avatar
Default Re: (fmfkid250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">I took a few plates of steel and did it in an hour... and less than $10...i left the center in place cut a hole in a plate and welded away!</TD></TR></TABLE>
just be ready for some shaking!
Old Jan 21, 2007 | 11:52 AM
BB6-213's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">homemade...
Very nice job, What did you use to fill it?
Old Jan 21, 2007 | 07:49 PM
ep3_04's Avatar
Default Re: (BB6-213)
This might help http://forums.evolutionm.net/s...66558
Old Jan 21, 2007 | 08:28 PM
JSpin's Avatar
Default Re: (solbrothers)
if you want a SOLID mount, weld a big washer on each side of the mount. i probably wouldn't do it if you have any dental fillings though
Old Jan 21, 2007 | 08:30 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (ep3_04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep3_04 &raquo;</TD></TR><TR><TD CLASS="quote">This might help http://forums.evolutionm.net/s...66558 </TD></TR></TABLE>
i like how he just guesses on the placement of the center pin.....
Old Jan 22, 2007 | 07:35 AM
fmfkid250's Avatar
Default Re: (OnlyHJC)
He said he wanted a solid motor mount!
Old Jan 22, 2007 | 04:03 PM
i used liquid urethane from mcmaster.com you can chose from 60a, 80a, or 94a shore (stiffness).
the p/n is 8644K18
Modified by raceACCORDingly at 1:28 AM 1/25/2007
Old Jan 22, 2007 | 05:17 PM
97grnrs's Avatar
i thought about welding big washers on the both sides of a mount but dont the engine need some flex? cause if its solid on all mounts wont the torque start breaking stuff.?
Old Jan 22, 2007 | 06:47 PM
paulzy's Avatar
Default Re: (ATS*Mark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*Mark &raquo;</TD></TR><TR><TD CLASS="quote">
i like how he just guesses on the placement of the center pin.....</TD></TR></TABLE>
lol, I was thinking the same thing
Old Jan 22, 2007 | 07:10 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwyndsdime &raquo;</TD></TR><TR><TD CLASS="quote">anyone know of a place where I can buy solid motor mounts for a 95 prelude?
(I've searched and found nothing)</TD></TR></TABLE>
http://www.explicitspeedperfor....html
E-mail or ask for john
Old Jan 22, 2007 | 07:19 PM
accordking's Avatar
Default Re: (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">if you want a SOLID mount, weld a big washer on each side of the mount. i probably wouldn't do it if you have any dental fillings though </TD></TR></TABLE>
FYI, Honda mounts are made from CAST IRON which isn't recommended for any kind of welding. Eventually, the mount are going to crack.
Old Jan 22, 2007 | 07:26 PM
SPOOLINmatt's Avatar
Default Re: (accordking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordking &raquo;</TD></TR><TR><TD CLASS="quote">
FYI, Honda mounts are made from CAST IRON which isn't recommended for any kind of welding. Eventually, the mount are going to crack. </TD></TR></TABLE>
what in the hell mount are you talking about that is cast iron??? The only ones ive seen are the aluminum ones on the driver side or plate steel welded up with a rubber mount like the tranny side?
Old Jan 22, 2007 | 07:55 PM
accordking's Avatar
Default Re: (SPOOLINmatt)
Honda factory. If it was CAST STEEL, yes, it would be weldable.
Old Jan 24, 2007 | 09:29 PM
AdamB18C1EK's Avatar
a way i have found to make really solid motor mounts is to get a piece steel they sell at lowes. they sell it in 4 foot sections. its 4 inches wide and 1/8 inch thick. if you know how to use a grinder and a MIG welder then you pretty much have it made. this piece of metal is about 17 bucks but forget about ever using any of your mirrors again and remove any change or other items from your cup holders
Old Jan 26, 2007 | 03:56 PM
OnlyHJC's Avatar
Default Re: (AdamB18C1EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK &raquo;</TD></TR><TR><TD CLASS="quote"> but forget about ever using any of your mirrors again and remove any change or other items from your cup holders </TD></TR></TABLE>
sad but true. i even have a pair of earplugs because after a day of drving around like that you cant hear for ish
Old Jan 28, 2007 | 06:14 PM
accordking's Avatar
Check it out
https://honda-tech.com/zerothread/1878187
HseriesWeaksauce
May 5, 2009 10:20 AM
invasian_boy
Oct 4, 2006 01:40 PM
KS-R
12
Feb 4, 2003 05:29 PM
bigTom
Jan 27, 2002 05:01 PM
