solid motor mounts
Old Jun 22, 2005 | 11:39 PM
sa594's Avatar
Default solid motor mounts
Does anyone out there make solid motor mounts for a GSR? Not looking for filled ones but a solid one. Thanks
Old Jun 23, 2005 | 03:54 AM
underpressure02's Avatar
Default Re: solid motor mounts (sa594)
I made a set for my car. Got the idea and help from dturbocivic
Old Jun 23, 2005 | 06:17 AM
YZFR6's Avatar
Yeah we have them just give us a call and I'll steer you towards the nearest dealer. Toll free 866-507-2843
Old Jun 23, 2005 | 05:16 PM
paulzy's Avatar
just weld tabs on your stock mounts...weld metal tabs from the inner race to the outer steel portion
I forgot who use to run it like that...it was a pro class all motor car. If I remember right, it was Jeremy lally or something like that...
Modified by paul vang at 8:42 PM 6/23/2005
Old Jun 23, 2005 | 05:20 PM
11SEC CIV's Avatar
Default Re: (paul vang)
i have avid racing mounts
dont expect to ever see through your mirrors again though
Old Jun 23, 2005 | 09:16 PM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">just weld tabs on your stock mounts...weld metal tabs from the inner race to the outer steel portion
use metal "disks" with holes drilled in them for the bolts to go through. weld one plate in, fill the mount with window weld, then weld up the other side.
Old Jun 23, 2005 | 09:21 PM
tony1's Avatar
Modified by paul vang at 8:42 PM 6/23/2005</TD></TR></TABLE>
I've done that quite a few times, make plates that go from the outer to the inner and weld it up. Nobody had solid ones for sale at the time though, i'd buy the Avid ones, it's a pain in the *** making them!
Old Jun 24, 2005 | 12:35 AM
sa594's Avatar
Thanks for all the info, really appreciate the help. If anybody else has ideas please post up.
Old Jun 24, 2005 | 04:27 AM
91civicDXdude's Avatar
i used the washers that came with an old energy suspension insert kit and just welded them solid to the mounts to make solid steel mounts.
Old Jun 24, 2005 | 05:23 AM
Drag-Accord's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
I've done that quite a few times, make plates that go from the outer to the inner and weld it up. Nobody had solid ones for sale at the time though, i'd buy the Avid ones, it's a pain in the *** making them!</TD></TR></TABLE>
We also did this. Say goodbye to wheel hop forever
Old Jun 24, 2005 | 06:22 AM
DaveF's Avatar
Default Re: (Drag-Accord)
i think solid mounts are good, but an engine plate would be better.
honestly, the mounts on my car, are solid, but they arent in the right locations to be "most effective" you would need to make all 5 mounts solid to have the most effective setup. i can still "rock" my engine. making the mounts can be time consuming. its all fun and a good learining experiance though.
Old Jun 24, 2005 | 09:44 AM
ModenaTwinTurbo's Avatar
Default Re: (Dturbocivic)
engine plate??? what do you mean? how does it look?
Ed-
Old Jun 24, 2005 | 11:00 AM
IMO making only the front and rear mounts should be plenty, since those are the torque mounts. as long as their solid, no real force is being placed on the driver side and side tranny mount
Old Jun 24, 2005 | 11:05 AM
tony1's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">IMO making only the front and rear mounts should be plenty, since those are the torque mounts. as long as their solid, no real force is being placed on the driver side and side tranny mount</TD></TR></TABLE>
Old Jun 24, 2005 | 11:21 AM
4piston's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">i think solid mounts are good, but an engine plate would be better.
Just curious...how much is it rocking and why is it rocking?
Old Jun 24, 2005 | 03:37 PM
paulzy's Avatar
yeap, it'd be a bitch trying to secure the rear mount with solid side mounts
Old Jun 24, 2005 | 03:51 PM
DaveF's Avatar
Default Re: (4piston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston &raquo;</TD></TR><TR><TD CLASS="quote">
Just curious...how much is it rocking and why is it rocking?</TD></TR></TABLE>
well. id say it moves about a 1/4 of an inch.. my rear mount is just a place racing crossmember mount, and the 2 other mounts i have, are in the centerline of the crank.(top trans mount, and timing belt mount) it would be better to have the mounts further out from the centerline on the crank. such as the 2 lower torque mounts, that attach to the framerails.
ModenaTwinTurbo
engine plate, such as Gardella's on his civic. it goes between the engine and trans, mounts to the front crossmember and the subframe. made from ~~1/4inch aluminum plate.
Old Jun 24, 2005 | 07:32 PM
ahh cool thanks
Ed-
EduardoDC5
16
Jan 8, 2009 10:52 AM
GuCBlackEk
Oct 2, 2008 06:06 AM
Mangkonethong
Jun 2, 2007 03:05 PM
yurasuka
Dec 8, 2006 09:06 PM
jarel
Dec 17, 2004 04:28 PM
