Slicks
Old Mar 25, 2010 | 04:31 AM
heavy duty's Avatar
Default Slicks
I have lenso and 24.5-9-13 mt and they r spinning on the rim really bad it there any thing i can do to stop besides screwing them. The car is 2600 and i run them at 6 psi. thanks for any help.
Old Mar 25, 2010 | 01:14 PM
A.E Motoring's Avatar
Default Re: Slicks
bead lock is usually how everyone stops it
Old Mar 25, 2010 | 01:59 PM
Innes's Avatar
Default Re: Slicks
just screw them
Old Mar 25, 2010 | 02:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Slicks
normally id make an assanine comment hahaa. but yes, screw em.
knockingon wood, but i dont know how im not spinning mine on the wheel.
i should pin mine also.
Old Mar 25, 2010 | 02:21 PM
heavy duty's Avatar
Default Re: Slicks
I just really dont like the way screwing them looks.
Old Mar 25, 2010 | 02:38 PM
welfarepc's Avatar
Default Re: Slicks
function > form.
you can try breaking the bead, cleaning the rim with some brake clean and re-seating them. maybe who ever mounted them used too much soap or some silicone lube etc to mount them.....
Old Mar 25, 2010 | 02:44 PM
Mr. Badwrench
Default Re: Slicks
well if you want them to stop slipping on the wheel, you are limited in your options.
Old Mar 25, 2010 | 02:53 PM
01DC4's Avatar
Default Re: Slicks
will, the exospeed beadlocks only work on exospeed wheels?
Old Mar 25, 2010 | 04:18 PM
cjordan's Avatar
Default Re: Slicks
Just buy some screws and put them in, did it on mine took my time and measured it and turned out really good.
Old Mar 25, 2010 | 04:52 PM
PyroProblem's Avatar
Default Re: Slicks
6 psi, isnt that a little on the low side?
Maybe adding a little air will help?
I dont know. I havent ran slicks in a long time...
Old Mar 25, 2010 | 06:03 PM
narfdanarf's Avatar
Default Re: Slicks
There are aftermarket beadlock producers who can make a beadlock and weld it on to your lenso this is what a lot of the rock crawler guys do.
Old Mar 25, 2010 | 06:07 PM
FastEg6's Avatar
Default Re: Slicks
Isn't there a type of sticky spray you spray around the rim or the bead??? Maybe that will help, not sure just another suggestion. I never tried it. I have mine screwed in.
downest
Sep 17, 2006 10:10 AM
raene
Aug 22, 2006 09:14 PM
2xtrme
Jul 4, 2004 04:08 PM
MaxBoost
Apr 11, 2003 02:59 AM
Pinhead
Apr 11, 2002 03:53 PM
