slick problems
Old Feb 12, 2009 | 06:57 PM
alonsobuiltmotors's Avatar
Default slick problems
ive searched and searched so i had to post i just picked up new lenso 13x7.5 and new m/t 24.5x8 i cannot get the bead to pop i can get almost all of it except for a little area. ive done the rachet around the tire used lots of lube and have gone upto 60psi still wont pop any know the secret or had this same problem . could it be the powder coat on the rims
Old Feb 12, 2009 | 07:16 PM
HamiltonRex's Avatar
Default Re: slick problems
Mine took 80psi to seat them. Goodluck. I used tubes as well.
Old Feb 12, 2009 | 07:28 PM
im afriad with the wrinkle walls being thin and blowing out ya kno? 80psi duck and cover
Old Feb 12, 2009 | 07:38 PM
hionvtecxda6's Avatar
We mount over 200 sets of wheels and slicks every year with our wheels and they mount up usually on the first try. We do use a bead grease to help it pop the bead, but you can have the same effect with a soapy water solution. We usually never have to go past 30psi to get the beads to sit. Its not the powdercoat at all. Thats never been an issue at all. Its just the way you grease it up, thats how it helps pop into the bead.
Exospeed Racing Wheels
Old Feb 12, 2009 | 07:52 PM
ill try it again greasin better thanks
Old Feb 12, 2009 | 08:13 PM
418whpturboD's Avatar
dude be careful id be scared at 80 psi..
Old Feb 12, 2009 | 08:27 PM
i am in no way doin 80psi lol dont worry i just gonna try and grease them better
Old Feb 13, 2009 | 03:17 AM
boostedcivicsir's Avatar
Mr. Badwrench
just mounted mine yesterday, i use soapy water. take out the valve core, air them up to 40, deflate, air it up again, deflate, repeat til the bead pops. it usually moves a little at a time.
Old Feb 13, 2009 | 05:15 AM
BlakeJ53's Avatar
Have you tried bouncing it? I built aircraft rims and tires for the Navy and when ours dont seat we bounce and air them at the same time only were doing it with 400 psi.
Old Feb 13, 2009 | 10:03 AM
We dont suggest airing them up that high. Ya its tempting to pump it up high to see if it would pop the bead, but it really just needs better lubrication. It might take a few times of airing them up, deflating them, rotating the tire a bit to pop it into the bead. Boostedcivicsir procedure is correct, take out the valve core when you put air in them. That makes a difference as well.
Old Feb 13, 2009 | 11:37 AM
did it berfore i just dont think its lubed enough. so ima go try them now i need to make soapy water anyway i have an air bag leak on my truck somewhere i found out by grindin the back of my bed down on the way home lol
Old Feb 13, 2009 | 02:33 PM
mike93eh2's Avatar
mine usually take 50psi to seat the bead...even though it says on the tire do not exceed 30psi when seating bead or something lol.. try hitting the tire when youre airing it up.
Old Feb 13, 2009 | 03:16 PM
base-op.1320's Avatar
I had the hardest time with the exact same rims and tires. One mounted at around 80psi third try but the other seriously took about 20 tries with just over 100psi lubed with rachet strap behind a fork truck about 35ft away. I was really sketchy about trying it but just couldn't get it to go. It has to be something about certain m/t with old lensos? I have had mh tires with exospeeds and they beaded no problem?
Old Feb 13, 2009 | 03:30 PM
mike93eh2's Avatar
yup, mine were lensos and 24.5" mt's
Old Feb 15, 2009 | 05:09 PM
gearhead16's Avatar
lube em up real good put like 30 psi in them and bounce em a couple times or use a rubber hammer to hit around spot that wont pop it will pop mine took a couple trys at 45psi
Old Feb 15, 2009 | 08:33 PM
SiKnezzALLmotor's Avatar
soapy water works fine
Old Feb 15, 2009 | 09:23 PM
streetracer6rpt's Avatar
just use lighter fluid and a match..
tepid1
Sep 13, 2012 12:32 PM
Tiger_Si
Nov 15, 2008 09:36 AM
PM-Performance
Jun 14, 2004 10:30 AM
PM-Performance
Jun 7, 2004 07:16 AM
96dc2
Feb 17, 2004 02:49 AM
