Simple radiator question
Old Jun 7, 2007 | 05:48 AM
HybridKOOP's Avatar
Default Simple radiator question
Simple question guys. SFWD Civic, running half-size radiator obviously... Who makes a half-size radiator for 92-95's that have a 1 1/4 inch inlet/outlet?
Most I have seen are 1 1/8, which is Civic radiator hose sizing. I want a nice and tight connection, so it must be 1 1/4. Anyone?
Old Jun 7, 2007 | 05:53 AM
ykracing's Avatar
Default Re: Simple radiator question (HybridKOOP)
Koyo makes one designed for a Bseries in a civic, with larger outlets.
Old Jun 7, 2007 | 07:37 AM
b18bturbo's Avatar
Default Re: Simple radiator question (ykracing)
chepeast method would be cut and weld it to your specs but getting koyo is alot more than the cheaper ones on the market.
Old Jun 7, 2007 | 08:03 AM
Turbocivic94's Avatar
Default Re: Simple radiator question (b18bturbo)
Lou I would recommend KOYO, I've used fluidyne and pwr before. Koyo keeps my car a lot cooler than others.
Old Jun 7, 2007 | 08:07 AM
HybridKOOP's Avatar
Default Re: Simple radiator question (Turbocivic94)
KOYO's are also thicker (in depth) over the Fluidynes, PWRs, etc... Leaving less room for fan/DP fitment.
Old Jun 7, 2007 | 06:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">KOYO's are also thicker (in depth) over the Fluidynes, PWRs, etc... Leaving less room for fan/DP fitment.</TD></TR></TABLE>
I run 4" downpipe with mine and it works fine. car never goes over 1/4 on temp gauge.
Old Jun 7, 2007 | 06:54 PM
tony1's Avatar
We run a PWR and the hoses fit tight, i think i remember hearing that PWR offers both the small inlet/outlet and the bigger one.
Old Jun 7, 2007 | 07:12 PM
kyden's Avatar
mishimoto! it was a really tight fit for hoses, i literally had to shove it on.
Old Jun 8, 2007 | 07:52 AM
gsrious's Avatar
Default Re: Simple radiator question (kyden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden &raquo;</TD></TR><TR><TD CLASS="quote">mishimoto! it was a really tight fit for hoses, i literally had to shove it on.</TD></TR></TABLE>true. just make sure your getting the right one. call them(seller/dealer) if you have to.
Old Jun 8, 2007 | 09:39 AM
TheWickedOne's Avatar
Louis, I'd recommend the PWR - The inlet and outlets fit nice and tight.. Laskey has them in stock i believe..
Old Jun 8, 2007 | 10:55 AM
ninesecrx's Avatar
Default Re: Simple radiator question (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">We run a PWR and the hoses fit tight, i think i remember hearing that PWR offers both the small inlet/outlet and the bigger one.</TD></TR></TABLE>
They only make it for the b series inlet/outlets. My STOCK single cam daily driver has a pwr radiator and its a stretch to get the hose on the radiator...but it can be done.
Old Jun 8, 2007 | 12:14 PM
MARC P's Avatar
Luis, run a stock 99-00 Civic SI they have the bigger outlets if you want to save money.
Marc P
Old Jun 8, 2007 | 12:58 PM
HybridKOOP's Avatar
Default Re: (MARC P)
I ordered a PWR so the outlets are already the larger of the two
Cowl287
Aug 1, 2008 03:19 PM
Maxpower350
Jul 16, 2006 06:56 PM
spoolingb20
Aug 15, 2005 04:14 PM
dAng! Kris
Apr 6, 2005 07:40 PM
