Should I try something different?
Old Apr 27, 2006 | 02:22 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Should I try something different?
So after two years of dragging my feet about my old car getting stolen, I finally got a new one and got it up and running and made it's first trip out of the garage for the first time to the H-T Capitol Raceway meet a little while ago. 92 Civic CX, Street Modified trim minus a built engine. Took some 22x8x15 MT's with me.
I figure we'd start off with 12psi. Single spin through the water. Pull forward and do a nice 4-5 second burn out. Staged, 6,500rpm. Partial throttle, no 2-step yet. Pre-load, drop, bog. Hmmm 2.1 60'. Check the pressure, reset to 12psi, rinse repeat. Change to 7,000rpm. Bog, 2.0 60'. Hmmm. Reset pressure to 12psi, 7,500rpm, bog slightly less 1.9 60'. Still not happy, but neither were the rain gods as they unleashed and ended my night.
So what are my options for next time?
1. Run more pressure?
2. Stop being a ***** and launch off the limiter full throttle?
3. Since is just test and tune, stage, weight for the first yellow, then full throttle it down and when it reaches around say 7,000-7,500 drop the clutch so it's a full throttle launch instead of a partial throttle. Does this even sound like a good idea? Or am I just babbling here?...
4. Stop being a ***** and build the engine already.
Ok ignore number 4 temporarily. It's getting there.
Thanks.
Old Apr 28, 2006 | 12:19 AM
JL's Avatar
JL
Default Re: Should I try something different? (Mr Hammond)
wow, this thread had 0 views, im surprised nobody has read it, h-t is full of people who want to give their input
you said you do a spin in the water box and then pull out and burnout? im assuming 1st gear? you could try 2nd gear at the edge of the waterbox until they start smoking.. should pull you right out of the box.. but what motor is in the car?
Old Apr 28, 2006 | 02:37 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Should I try something different? (JL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL &raquo;</TD></TR><TR><TD CLASS="quote">wow, this thread had 0 views, im surprised nobody has read it, h-t is full of people who want to give their input
you said you do a spin in the water box and then pull out and burnout? im assuming 1st gear? you could try 2nd gear at the edge of the waterbox until they start smoking.. should pull you right out of the box.. but what motor is in the car?</TD></TR></TABLE>
I don't need MORE traction. LOL! Stock USDM B18C1.
Old Apr 28, 2006 | 05:41 AM
nerdsports's Avatar
if you're bogging off the hole, you should launch higher, maybe off the rev limiter.
Old Apr 29, 2006 | 07:10 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">if you're bogging off the hole, you should launch higher, maybe off the rev limiter.</TD></TR></TABLE>
Looks about like my only choice at this point.
tarpus91
Engine Management and Tuning
Apr 15, 2017 04:19 PM
josephcmiller2
Aug 29, 2011 11:34 AM
92HB_HB
Jul 10, 2010 11:17 AM
cadeMFjohnson
Aug 5, 2009 12:57 AM
B18 CYA
Jul 17, 2006 03:51 PM
