Oil Pressure readings..
Old 04-22-2002, 07:03 PM
92HB_HB's Avatar
Default Oil Pressure readings..
what are your typical oil pressure readings at full/part throttle?? I need some numbers to see where I'm at and to see if i'm in the normal range, which is around 60-75 psi when on the throttle or above 2.5K rpm.... etc..
Old 04-22-2002, 08:48 PM
synergy004's Avatar
Default Re: Oil Pressure readings.. (92HB_HB)
haha turbo LS hatch here buddy, baddass torque and top end with my new .46 turbo form my previous 60-1.
your pressure should read at start up 60 psi could be close to more or a lil less. at full throttle it is steady at 50-60 psi. at warm up and motor at idle should be from 20 psi to 30 psi, depends on where you have your timing set. all this could play a factor.
boost that LS hatch boiiiiiii what are our times if you ran any.
p out
Old 04-22-2002, 09:02 PM
92HB_HB's Avatar
Default Re: Oil Pressure readings.. (synergy004)
hit the track the other weekend... ran a best 14.0, no MPH cuz the track comp was not working... this was on a slipping clutch and 8 psi.. my best mph was 101.7 mph @ 14.5 sec.. horrible 0-60ft..
gonna try again when i get the new clutch broken in.. hopin for low 13's at least..
Old 04-22-2002, 09:09 PM
synergy004's Avatar
i take it this was ran on stock tires too. , not bad mph could be a lil better. Change that clutch though big diffy when you do.
happy boosting
Old 04-22-2002, 09:11 PM
92HB_HB's Avatar
forgot to mention.. all this was done on 555r's.. didn't get any decent burnouts either.. car would move forward even with the rear wheels locked...
Old 04-22-2002, 10:04 PM
quikrpm'z's Avatar
at idle i only get a reading of 12psi, driving the max i see is 50.
Old 04-22-2002, 10:08 PM
93LSivic's Avatar
Damn, why is everyone else's so low. At redline high rpm i am seeing 90-95 psi of oil. At idle about 25 and part throttle about 65.
Why is this? 94 ls turbo motor in my hatch too??? hmmmm
Old 04-23-2002, 06:54 AM
synergy004's Avatar
Default Re: Oil Pressure readings.. (93LSivic)
damn dude your in the 90's. I checked my bros and hes near the same as mine. mine read higher one time because i overfilled with oil. yours seems kinda high.
Old 04-23-2002, 11:59 AM
Honda Hick's Avatar
at idle i'm at about 18-22psi. When i'm on it though i hit about 80 psi and cruising i'm at like 65.
Old 04-23-2002, 07:25 PM
quikrpm'z's Avatar
Default Re: Oil Pressure readings.. (Honda Hick)
what oil pressure gauge does everyone have? I have an autometer(electrical).
Old 07-07-2010, 10:52 PM
LsDecepticon's Avatar
so do we have a base line pressure here? im trying to help a friend?
Old 07-09-2010, 07:34 AM
Deatschwerks's Avatar
The warm pressure at idle on my B16B w/ 30 weight oil is 22-25psi.
On track at race temps and WOT, high-rpms it's between 80-90psi.
It's a NA application, BTW.
Old 07-09-2010, 08:22 PM
twkdCD595's Avatar
I see 90+psi with any real load or decent amount of rpm and around 40 psi at idle... with car well up to temperature.
Old 07-09-2010, 09:05 PM
TorganFM.'s Avatar
9psi per 1000rpm is the lower service limit iirc
Old 07-10-2010, 11:17 AM
blackeg's Avatar
good. i see just about 90 psi at 8500ish rpms.
60-70 cold idle, 20-30 warm idle. usually around 75ish just cruising. 10w-40 in a vtec motor.
im using an autometer electrical which suck pretty bad honestly, ive had 1 sending unit go bad on me already and i dont even have it hooked up half the time.
as for the car creeping foward, do those burnouts in 2nd gear with the ebrake yanked all the way up
SiRacing
08-07-2009 12:22 PM
Smooth-GSR
07-19-2004 06:38 PM
scatuli
04-09-2004 01:32 PM
Toda Party
04-24-2003 03:56 PM
HX_Guy
12-04-2001 05:13 PM
Quick Reply: Oil Pressure readings..
