short rams??
Old May 12, 2003 | 11:03 PM
integraL's Avatar
Default short rams??
does anyone have an AEM short ram intake for their GSR? if so, can you give me some feedback?
Old May 13, 2003 | 09:55 AM
10seconds's Avatar
Honda-Tech User
Default Re: short rams?? (2001gsRguy)
just like any other hot air intake....i mean short ram...
steve
Old May 13, 2003 | 05:33 PM
96dc2's Avatar
What do you want to know? Is this even in the right forum? Try the integra forum.
Old May 13, 2003 | 06:56 PM
TeamTooQuick's Avatar
Default Re: short rams?? (96dc2)
Well if this helps i have a Injen CAI and i used to have a AEM CAI and both where cut in half so i can switch to short and cold air. When i have the cold air pipe off i could feel a difference in top end....
Old May 13, 2003 | 09:30 PM
integraL's Avatar
Default Re: short rams?? (TeamTooQuick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick &raquo;</TD></TR><TR><TD CLASS="quote">When i have the cold air pipe off i could feel a difference in top end....</TD></TR></TABLE>
whats the difference? is it stronger? or weaker with the cold air pipe off?
Old May 14, 2003 | 04:25 AM
PUSHER's Avatar
Your top end is technically better because it requires less effort for the air to get to your engine. CAI is good for low end, mid range power. Short ram intake should be okay for the first couple of runs, but after that engine temps affect the intake air.
Old May 14, 2003 | 05:46 AM
bottlefedb18c1's Avatar
Default Re: (PUSHER) t
i see it as if you have a cold are there is going to be more friction with the aire due to that it is travaling though more pluming and there is less pluming with the short ram but on the other hand the cold air is more cooler air then the short ram
so i went with a short ram with spray and it will have less friction and restriction with alot colder air and it runs like a champ
Old May 14, 2003 | 08:17 AM
9200RPM's Avatar
Mine is from AutoZone....it goes ERRRRRRRRRRRRRR when i step on the gas....YAAAAAAEHHHH!!!!
mrnewguy
68
Aug 13, 2006 08:55 AM
blk94gsr
Jan 17, 2006 05:47 PM
kenken613
Aug 29, 2005 10:52 AM
krnfly2damoon
Jul 6, 2005 02:32 PM
IloveAPC
Sep 15, 2004 07:16 AM
