to shift, or not to shift...
Old Aug 31, 2008 | 10:22 AM
kalm_traveler's Avatar
Default to shift, or not to shift...
If I'm topping out 3rd just a little before the 1/4 mile sensor should I even bother shifting up to 4th?
Old Aug 31, 2008 | 10:28 AM
DaveF's Avatar
Default Re: to shift, or not to shift... (kalm_traveler)
lol get a new trans ....... ASAP
Old Aug 31, 2008 | 11:03 AM
Default Re: to shift, or not to shift... (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">lol get a new trans ....... ASAP</TD></TR></TABLE>
It's just in my stock S2k...
4200ft elevation and bad launcher = 92-93mph trap speeds. fuel cuts out about 94-95 in 3rd gear
Old Aug 31, 2008 | 02:21 PM
anybody have any helpful input? God-willing I'll figure out how to launch by next season so should be closer to 100mph which will require 4th gear but I'm just curious...
Old Aug 31, 2008 | 03:26 PM
BoostFlow's Avatar
Banned
if its stock and you dont want to [freak] with it to much why not just try a taller rear tire
Old Aug 31, 2008 | 04:41 PM
Adriano's Avatar
Default Re: (BoostFlow)
If you are trapping 92-93 and the car reaches 94-95 in 3rd, why would you need to shift?
adriano
Old Aug 31, 2008 | 04:56 PM
NAH2B's Avatar
Default Re: (Adriano)
what rpm do you make power to and what rpm is your rev limit?
Old Aug 31, 2008 | 08:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">If you are trapping 92-93 and the car reaches 94-95 in 3rd, why would you need to shift?
adriano</TD></TR></TABLE>
3rd gear calculates to 94-95 at 9000rpm. If I hold 3rd through the last little bit I hit fuel cut, and my fastest trap speed was 92.89mph with stock size tires. Just trying to figure out if shifting to 4th around 8800rpm would help?
NAH2B -
I believe peak power is around 8600 or so, fuel cuts at 9k. VTEC starts at 6k.
Old Sep 1, 2008 | 03:52 AM
2point2's Avatar
Default Re: (kalm_traveler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kalm_traveler &raquo;</TD></TR><TR><TD CLASS="quote"> Just trying to figure out if shifting to 4th around 8800rpm would help?</TD></TR></TABLE>
The easiest way to figure this out is to just go to the track and try it......
Old Sep 1, 2008 | 09:34 AM
maxwellsohc's Avatar
Default Re: (2point2)
if you can play with your limiter by lets say 200rpm higher you'll probly fix that problem. remember it will be higher in 1 2 & 3 that should almost cover approx 100ft.
Old Sep 1, 2008 | 05:00 PM
crxk26's Avatar
Default Re: (maxwellsohc)
x2 on that
mcc361
Sep 4, 2007 12:38 AM
Blackline47
Honda Civic (2006 - 2015)
16
May 27, 2007 10:48 PM
goose21
Sep 20, 2004 08:38 AM
megotvtec
Apr 18, 2004 06:26 PM
SKDRCR
Aug 21, 2003 07:50 AM
