setup
Old Feb 14, 2003 | 03:31 PM
12SecHatch's Avatar
Default setup
how much do you think this setup is worth?????
and is there any of this that yoU CAN NOT RUN IN THE QUICK, pro 4cyl, hot rod classes
mild steel 8 point roll cage with integrated cro-moly wheelie bars
Skunk2 race coilovers with tokico blue struts
Jamex non-adjustable racing seat w/simpson 5 point harness
GT grant steering wheel
Autometer 2 1/16 guages, air/fuel, boost pressure, fuel pressure, nos pressure, water temp, and oil pressure. 5" tach
Bogart D-fly 13x8 with M/T 24.5x9 slicks on front
Bogart D-fly 15x3 with M&H 24x3 skinnies on rear
battery relocated to rear or car with shut down switch
Fuel Management:
Hondata stage 4 with boost option and data logging
OBD-0 to OBD-1 conversion harness with P28 ECU
Aeromotive 1000hp fuel pump and filter
-8 fuel lines
AEM fuel rail bored to fit holly injectors
Holly 950cc injectors
Holly FPR 1:1
Stock fuel tank
Motor:
LS/Vtec
B18A1 LS block with Benson full metal jacket with copper O-rings
JE 9.5:1 GSR pistons
Crower connecting rods with arp rod bolts
Pro Drive oil pump
ARP head studs
Fully balanced and blueprinted assembly
GSR B18C1 head and stock cams
Skunk 2 intake manifold plumed for 4 fogger NOS kit
Crower dual springs and titanium retainers
Ferarra stainless steel valves
Drivetrain:
1993 LS cable transmission with Pro Drive Spool
STR scatter shield
Turbo/NOS setup:
Air Research custom straight T4 with T3 exhaust flange
Fmax log style manifold
Greddy type R wastegate
Greddy type R blow off valve
Turbo XS dual stage boost controller
Spearco dual core liquid to air intercooler mounted inside of car
3 gallon water cell mounted on cage with water pump
NOS big shot 4 fogger wet kit with purge
colbynorwood
Jun 10, 2013 02:05 PM
midwesta
10
Aug 3, 2005 03:06 AM
servion
Jun 8, 2004 11:20 PM
Red D Dragon
34
Apr 5, 2004 04:51 PM
Trajic
Oct 3, 2001 12:37 PM
