Sept WTB Thread
Old Sep 1, 2011 | 12:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Sept WTB Thread
Please read the rules for the new thread
1) This is for
RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If you find what you're looking for please remove them from your post. If you find everything off of your list of parts, report your post to moderator by clicking on the just under your user name and I will delete it.
3)You are ONLY allowed ONE post in this thread, if you are found to have more than one post, all of your posts will be deleted.
4) NO FS ADS!
5) KEEP REPLIES IN PM'S
We will delete any BS we feel does not belong in here
From this point on, 1-1-2010, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. This will be adhered to. No more warnings.
Old Sep 1, 2011 | 01:26 PM
YAGGA_YA's Avatar
Default Re: Sept WTB Thread
in need of a sleeved bseries block asap
Old Sep 1, 2011 | 01:28 PM
JDM346's Avatar
dual bosch 044 fuel pump setup...with filters and lines...-10 feed -8 return....fpr...fuel rail...fittings
Old Sep 1, 2011 | 03:02 PM
92redhatch's Avatar
Omni 4 bar map sensor.
Old Sep 1, 2011 | 05:04 PM
jiggacivic's Avatar
84mm GE headgasket
Old Sep 1, 2011 | 06:23 PM
chapnutz1's Avatar
4channel CDI box....thanks
Old Sep 1, 2011 | 08:13 PM
slowesteg's Avatar
lenso w/23 slicks
Old Sep 2, 2011 | 03:23 AM
mrbigg9032's Avatar
WTB: DSS D Series 2.9 Axles.
Old Sep 2, 2011 | 10:51 AM
Gkdc182's Avatar
WTB
99 civic front and rear camber kit.
Old Sep 2, 2011 | 03:41 PM
SwappedTURBOegg's Avatar
looking for b series hydro twin plate used/cheap and springs/retainers need asap
Old Sep 3, 2011 | 07:15 AM
wreckeddc4's Avatar
Looking for a pair of 13" lensos, any color, with or without slicks. I'd like 22" slick if possible for all motor. Lmk!
Old Sep 3, 2011 | 08:08 AM
Boostfed86's Avatar
WTB-
Avid solid mounts for EG/DC B-series
Traction bars
FJO injector driver
Old Sep 3, 2011 | 04:35 PM
allmotorCRX.'s Avatar
WTB a b.series ATI damper and a SSR street sweeper header
Old Sep 3, 2011 | 04:47 PM
xenocron's Avatar
Wtb K24 oil pump for high Revving...IE erl s2000 pump for k24 or type-s pump modded by Hytech or similar
Need this ASAP!
Old Sep 3, 2011 | 06:09 PM
BIGTUNA's Avatar
B18/LS Hydro trans MD,VA,DE, NJ
Old Sep 5, 2011 | 07:42 AM
d16z6Tcrx's Avatar
b series twin disc. 24.5x9x13 slicks. 1 gallan catch can.
Old Sep 5, 2011 | 11:17 AM
Desir Performance's Avatar
wtb ID 2000's with pig tails, racepack dash, super comp chute, wilson tb.
Old Sep 5, 2011 | 05:19 PM
mrbh22's Avatar
WTB traction bars and drag suspension for EK
Old Sep 6, 2011 | 06:49 AM
hatrickstu's Avatar
need a shiftlight or tach/shift light combo.
Old Sep 6, 2011 | 04:44 PM
DaFredsta's Avatar
Wtbeg,dc,ek) drag suspension ie: blox,omni,skunk2...
Old Sep 6, 2011 | 06:02 PM
90blackcrx's Avatar
WTB: h2b qsd eg kit
WTB: innovative ef d series hydro mounts
Old Sep 7, 2011 | 04:55 AM
MShonda's Avatar
WTB 2 rear coilovers for eg... prefer 10k or higher spring rate
WTB 70a or stiffer b series motor mounts eg. 3 bolt post
WTB skunk2 or victor x manifold for B18b1 ls
thanks
Old Sep 7, 2011 | 04:18 PM
dragallmotor24's Avatar
WTB: Weld Magnum 15x3.5 w/strange spindle mount, Gold or Polish
Old Sep 9, 2011 | 02:42 AM
eDm cRxXx's Avatar
WTB: used BIG cams for b-series (Pro3, M25, supercam, jun3, bumpsticks++)
Old Sep 10, 2011 | 06:02 PM
rickbeastwood's Avatar
Wtb. Ep3 idler pully
found one
