s300 help???
Old Oct 1, 2007 | 06:22 PM
laziebun's Avatar
Default s300 help???
Well my car is at a shop getting tune with HONDATA S300 and having an issue with the GM map sensor. When the tuner install the 3bar there is some kind interfernece of some sort, thinking that its elecrical, but not for sure. Wondering if anyone one else has had this problem or might know what the problem might be? i know this isnt alot of info but this is basically all he can tell me over the phone.
SET UP:
1999 civic
gsr
t3/t4
inline pro manifold
turbo smart 38mm WG
780cc precision with resitor pack
srp 9:1
eagle rods H BEAM
thermal 3" catback
S300
MSD blaster coil, distributer cap
NGK BKR7e Gap .30
Old Oct 1, 2007 | 06:25 PM
laziebun's Avatar
Default Re: s300 help??? (laziebun)
thinking it might be the MSD?????????
Old Oct 2, 2007 | 02:29 AM
Darrell Bs 10SecEG's Avatar
Could be the coil too close to the map sensor or Try adding some thick ground wires and ground the valve cover with a 10 gauge wire.Its worth a try.Like around 20 bucks worth of wire and ring terminals.
Old Oct 2, 2007 | 03:19 AM
TheWickedOne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote">Well my car is at a shop getting tune with HONDATA S300 and having an issue with the GM map sensor. When the tuner install the 3bar there is some kind interfernece of some sort, thinking that its elecrical, but not for sure. Wondering if anyone one else has had this problem or might know what the problem might be? i know this isnt alot of info but this is basically all he can tell me over the phone.
SET UP:
1999 civic
gsr
t3/t4
inline pro manifold
turbo smart 38mm WG
srp 9:1
eagle rods H BEAM
thermal 3" catback
S300
NGK BKR7e Gap .30
Can you explain how there might be some interference.. whats happening ?
Modified by TheWickedOne at 11:12 AM 10/2/2007
Old Oct 3, 2007 | 05:08 AM
B18c1turboedEK's Avatar
Default Re: s300 help??? (TheWickedOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by TheWickedOne at 11:12 AM 10/2/2007</TD></TR></TABLE>
Exactly.... I know when if the MSD box is cose too the ecu, it wont datalog at all, ive never heared of the map causing interference..
INCNTRL4
Dec 7, 2005 07:49 PM
Chris22215
Aug 25, 2005 11:30 AM
allablur
Nov 24, 2003 09:43 AM
Brian_92GSR
Feb 16, 2002 08:53 AM
