s300 bbg help
Old Jun 16, 2015 | 11:27 PM
jdm.fanatic's Avatar
Default s300 bbg help
So I have been messing with my boost by gear settings for a while now. I can't seem to get first and second gear to run the amount of boost that it's set to run. Its running lower. I have a mac 4 port and at first I was having fluttering issues that I got to go away by setting hz up to 45. Got my dc for boost table setup then pluged in what I want to run in each gear. Can't get 1st and 2nd to run high enough. I keep uping the boost for each gear but it doesn't raise it really.
Old Jun 17, 2015 | 04:26 AM
D-Rob's Avatar
Default Re: s300 bbg help
You may not have enough load in those gears to even make the amount of boost you're looking for.
Do you need the dynamic range the 4 port solenoids offer? (3psi spring and need 30psi of boost?)
Old Jun 17, 2015 | 06:53 AM
EJ1_Ex's Avatar
What spring rate do you have in the wastegate?
Old Jun 17, 2015 | 05:10 PM
6 psi spring. didn't have a problem last year running 23psi every gear with manual controlerror but it was too much
Old Jun 18, 2015 | 07:26 AM
extremeracer's Avatar
What size turbo ?
Also make sure your wastegate activation pressure setting is correct, this needs to be the same or close to your actual spring pressure, otherwise the solenoid can remain inactive and therefore you won't get target boost as the solenoid is remaining passive in the lower gears.
Old Jun 19, 2015 | 06:16 AM
HeikDiesel's Avatar
I run the VitViper PWM booster with a 4 port mac solenoid and the duty cycle vs psi increase is almost a 1:1 ratio. 3rd and 4th gear require a little more duty to maintain pressure but with a 6psi spring I'm able to run 35 psi with <50% duty cycle. I think the problem is with a 4 port that most of the time the duty cycle increase vs pressure increase is never linear so you just have to play with your settings or find a better boost controller.
Steeve_Civic
Oct 15, 2014 08:43 PM
dropped93ex
Nov 28, 2011 07:56 PM
n1neb4ll
Jun 19, 2003 07:18 AM
TurboedGSR
Feb 23, 2003 02:08 PM
Dee
Nov 22, 2001 06:39 PM
