rs machine
Old Nov 18, 2009 | 07:54 AM
alloutdc's Avatar
Default rs machine
i am trying to do alittle research before i make 1000 dollar mistake has anybod dealt with rs machine are their blocks worth the money can they hold up thanks
Old Nov 18, 2009 | 08:49 AM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: rs machine
Ive used them a few times. no problems at all
Old Nov 18, 2009 | 10:34 AM
092eg6's Avatar
product good, but last time i deal with them their customer service sucks big time! but i will apologies if they upgraded their customer service by now. good luck
Old Nov 18, 2009 | 10:46 AM
PPLH8R's Avatar
you should not have any problems. Dave C. is a stand up dude with a good product !!
Old Nov 18, 2009 | 09:06 PM
2.0 and up's Avatar
x2 their service sucks... seriously>>> i speak from experience
Old Nov 18, 2009 | 09:22 PM
A train's Avatar
dave is a no bs dude period! i deal with a couple different companys out there that do block and like i said dave is no joke!
Old Nov 19, 2009 | 03:47 AM
Boosted_B_Series's Avatar
Why spend 1k with rs machines and not 1k with golden eagle, they have sleeved more blocks than all the sleeving companies combined.
Mine was 1050$ shipped back to me, o ringed with 70psi/1300whp lifetime warranty sleeves. I shipped it to them in a big *** ups box, it came back in a little bitty ups box with my sleeved block wooden crated up inside.
My local machine shop was blown away by the quality of the work, and couldn't believe the low price charged. None of our local shops can touch that price with darton mids.
I think if I were to try another sleeve it would be the AEBS T sleeves, always wanted a set of those.
Old Nov 19, 2009 | 06:55 AM
champLSinteg's Avatar
My block is sleeved by RS and I have no issues at all.
Old Nov 19, 2009 | 08:01 AM
dragallmotor24's Avatar
Dave is a stand up guy...I sleeved all my honda and toyota motors with him. He just finished my 2ZZ celica motor with custom pistons and sleeves in a month...Just like he promised. RS machines & Dave has always given me the best sevice and products. Go with RS machines and you wont regret it!
Old Nov 19, 2009 | 10:27 PM
PPLH8R's Avatar
some people may not be aware that RS used to be owned by a different person than it is today. The machine shop was sold a few years back to its current owner. As far as I know when Dave took over, the shop was all good from that point on. Dave also owns a shop out in Phoenix "Import powerhouse" which has been open for nearly 10 years. If you have shitty service you wont stay open for ten years. My .02
Old Nov 19, 2009 | 10:41 PM
V-SPEC 1's Avatar
Yes, why not send your block to GE. they are one of the best out there hands down. By the way, I see a gap on your O-ring there............ JK.
Old Nov 19, 2009 | 10:59 PM
ninesecrx's Avatar
Where did that fact come from? Benson was installing iron ductile sleeves in blocks long before GE. The quality of RS sleeves are fine, but be prepared for out of round bores and not straight decks.
Old Nov 20, 2009 | 12:04 AM
IT'S ME DAVID's Avatar
NooB
is benson $1k
Old Nov 20, 2009 | 04:39 AM
trickeng's Avatar
why not GE? because they glue there sleeves in and if you break you motor, make sure you don't hot tank or jet wash it because then you'll be rebuilding again after the coolant taints your oil and your pistons scuf. They are the cheapest out there for a reason. Because there process lacks what more expensive sleeves offer. If they were $1000, there sales would fall of the earth.
Dave @ RS is good people, I've installed a few of there blocks and I've never had an issue with there sleeves. I currently use Darton's exclusively, since a local shop does them with extreme precision.
Old Nov 20, 2009 | 10:50 AM
ninesecrx's Avatar
Originally Posted by IT'S ME DAVID
is benson $1k
Cheaper plus lifetime warranty
Old Nov 20, 2009 | 11:40 AM
eagles3's Avatar
Why not get an ERL sleeved block. There's no doubt you will pay more money but the quality of work that you will receive from them will be top notch. They also will provide you with great customer service. Here is a picture of a Honda K24 block that's been assembled. It does not have O-rings because it is going to be using a standard gasket and they step deck their blocks to have a better seal in the combustion chamber. This means they leave the sleeves sticking up like .002"-.003" above the deck surface. O-ring is ok on a Honda block but really if you want a better seal you should just go with 1/2" head studs first because they are less maintenance and have 60% better clamping force than a standard sized ARP stud, then see if you still need more help and consider O-ring.
Seriously, you may want to consider spending the extra cash and getting something that will last for a very long time! They will sleeve it, deck it, hot tank, stress relieve, align hone (only bore if necessary. Not necessary in most cases) and finish cylinder hone to piston spec all for the price of the sleeving. 1500.00
Old Nov 20, 2009 | 02:24 PM
TOM J's Avatar
Old Schooler
Mike I can not beleave you are going to come on a public form and talk nonsence. I figured you have grown up over the years. (Guess not)
But comeing from a second rate racer and a third rate motor builder. I am not suprised.
Go figure.
Tom J
Old Nov 20, 2009 | 02:33 PM
MrParks's Avatar
rs machines are good people. never had a problem with them or golden eagle. but do understand rs machines and ge have different processes.
Old Nov 20, 2009 | 03:45 PM
ninesecrx's Avatar
Go figure.
Tom J
At least I am first rate at something huh?
Old Nov 20, 2009 | 06:31 PM
JDM_COUPE's Avatar
i not going to talk about **** but i havnt had any problems with RS like i have with other companies
Old Nov 20, 2009 | 07:38 PM
sheepey's Avatar
I like them all RS sleeved 2 of my blocks and never had problems
Old Nov 20, 2009 | 08:12 PM
ALL IMPORT's Avatar
thier all good u just dont want one that was done on a Monday ( hang over).
or a Friday (rushing to go home).
Old Nov 21, 2009 | 07:03 AM
locash's Avatar
TrickEng, regardless of your opinion on their process, you do realize that a lot of the record breaking cars are using GE sleeves, without failures due to GE's work. right?
I have a few blocks there right now, and have an ERL block in my car right now.
Old Nov 21, 2009 | 08:19 AM
newtype_33's Avatar
I`ve been using RS machine and never had any issue with the sleeved and Dave is really a kool guy customer service is A++++++
Old Nov 21, 2009 | 04:14 PM
91' LS-VTEC's Avatar
Benson & LASKEY RACING.
Mike, always willing to give a helping hand. .
