Roll cage rule question
Old Sep 27, 2011 | 06:15 AM
PhilStubbs's Avatar
Default Roll cage rule question
Long story short, my cage has to be bolted into the car. Welding is not an option. It's going into a 91 STD hatch. So far the main hoop and door bars went in fine. I got to the rear bars and ran into a problem. They land right on top of a frame rail. That means I can't just put a 6x6 plate under the floor like NHRA wants. Does anyone know if I can make an "S" shaped plate and use long bolts that go through the frame rail?
Old Sep 27, 2011 | 06:37 AM
tepid1's Avatar
Default Re: Roll cage rule question
Call NHRA.
484.515.7273 ask for Bob Nixon.
Old Sep 27, 2011 | 05:04 PM
blackeg's Avatar
Doesn't it say something about a minimum of 36 sqaure inches? If so then I wouldn't be suprised if you can use a slightly larger plate since you have met the min. Requirements. The phonecall to the aforementioned number is your best bet to be certain
Old Sep 28, 2011 | 03:01 AM
PhilStubbs's Avatar
I tried calling a couple times and left one message. No luck so far.
What I read of the rules was a 6"x6" plate on each side of the floor. The plate on top will be a square, flat 6x6 plate. The one under it will have the same footprint, but will wrap over the frame and use long bolts going through the frame.
I wish I could just weld it in but the race I'm doing has a budget cap on the car. If you weld the cage in it counts towards your budget, if you bolt it in then it doesn't.
mushroom samba
Mar 16, 2009 04:41 PM
The Collin
Jun 8, 2007 10:24 AM
RC000E
Welding / Fabrication
Jul 17, 2006 11:27 AM
Kev95lx
12
Apr 28, 2003 03:33 PM
Halo
Audio / Security / Video
14
Nov 19, 2002 11:04 PM
