Rochmond Spool
Old Sep 7, 2003 | 04:22 PM
9200RPM's Avatar
Default Rochmond Spool
I'm considering buying a Richmond spool for my Cable Tranny B16. Just wondering if anybody has them installed. I do drive this car on the street, and I am aware of the down side of having a spool on the street. Thanks for any and all help...
Cameron
Old Sep 7, 2003 | 04:43 PM
T4eg's Avatar
Default Re: Rochmond Spool (TurboB16aEG)
If you are going to drive it on the street i would get a quaife LSD. But if a drag car go with a pro drive spool
Old Sep 7, 2003 | 05:25 PM
Jared's Avatar
Should be pretty easy to install if you've ever had a trans apart before. Rich mond has a history of making good parts, you shouldn't have a problem. I had a spool in my street car for the last two years and I was OK with it at first, but after a while, all the driving problems and axle problems it introduces were enough for me. I pulled the trans last week to fix a reverse problem and ordered a quaife to put back in it.
GRTechnologies's Avatar
i have installed them and they fit and work fine but, everyone i've seen are made wrong. the splines on the half shaft side need to be back cut the axle doesnt go all the way in.
Old Sep 7, 2003 | 05:28 PM
Default Re: Rochmond Spool (Jared)
I use a pro drive spool but, they have problems, they fit fine and work fine but there skimpy on the splines they have striped out before
Old Sep 7, 2003 | 08:32 PM
9200RPM's Avatar
So basically it is more then a hassel then helpful..Like when I did my swap I took out the AC, when summer comes and I take a girl out shes like damn it's hot....and of course they don't like the windows down...Anyways...That's a little of topic...I just see how much cheaper they are then other LSD's...But of course the cheapest way out isn't always the best...Thanks for your help!!
Old Sep 7, 2003 | 08:40 PM
BoostinDC2's Avatar
richmond makes goos ****
Old Sep 7, 2003 | 09:08 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">But of course the cheapest way out isn't always the best</TD></TR></TABLE>
That's exactly what I found out, which is why after two years of fighting the spool on the street, I bought a quaife. If you want one, get in touch with Tom at http://www.camp1320.com/ and tell him I sent you.
Old Sep 8, 2003 | 10:17 AM
kwik92hb's Avatar
Thanks...That was the advice I was looking for...
Old Sep 14, 2003 | 05:58 PM
275Performance's Avatar
Default Re: (GR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GR &raquo;</TD></TR><TR><TD CLASS="quote">i have installed them and they fit and work fine but, everyone i've seen are made wrong. the splines on the half shaft side need to be back cut the axle doesnt go all the way in. </TD></TR></TABLE>
My TCI one is the same way. I have to get the splines brought back some to fit.
Old Sep 14, 2003 | 07:48 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Dude you should weld it...... j/k
Old Sep 14, 2003 | 08:26 PM
greenwonder's Avatar
Default Re: (v-attack)
Im always looking for good deals.
ls block and v-tec heads.
Richie@jdmcars.com
Old Sep 14, 2003 | 08:37 PM
I just worked on a customers trans who had a richmond installed
and it didt fit for ****. speed o gear hit housing. Did t start project just fixed it
who knows what they did.
Old Sep 15, 2003 | 05:05 PM
9200RPM's Avatar
Nevermind. I'm getting a JDM Hydro tranny with LSD for free. Just have to put new syncros in it...
CRISxMOB
Transmission & Drivetrain
Sep 7, 2012 02:10 PM
da9bigboi
Feb 28, 2012 09:30 PM
SPOOLINmatt
Jan 25, 2006 05:15 PM
1fastgsrturbo
Apr 3, 2004 06:26 PM
1fastgsrturbo
Apr 3, 2004 06:02 PM
