ring gears hate me!!!!!
Old Oct 17, 2006 | 01:06 PM
vtekthis's Avatar
Default ring gears hate me!!!!!
I dont know what it is, ive been preloading every pass, and i MEAN preloading it to alll hell, launching at about 15psi on 24.5's it gets low 1.7x 60's and keeps stripping the ring gear! the funny part is this is all on stock axles!!!! WTF you would think they would break instead.
I wanna know, if anyone knows a possible root cause for this? i think i would feel a good wheel hop but feels nice and clean, broke two races in a row, one on the launch (did not break the beams) and the other in first and still made it down the track , oh yeah stock ring and pinion
darren
Old Oct 17, 2006 | 01:22 PM
HR-1320's Avatar
Default Re: ring gears hate me!!!!! (vtekthis)
You can get a circiut works unit for like $600. Its a no brainer. Mine has held up on 28's And 1.3 60's.
Old Oct 17, 2006 | 01:47 PM
vtekthis's Avatar
Default Re: ring gears hate me!!!!! (2.0Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0Coupe &raquo;</TD></TR><TR><TD CLASS="quote">You can get a circiut works unit for like $600. Its a no brainer. Mine has held up on 28's And 1.3 60's. </TD></TR></TABLE>
deffinitely going to look into this, just wondering how the other "stock ring gear guys" are holding up for how long, and their failure percentage
Old Oct 17, 2006 | 01:52 PM
Flexmyrex's Avatar
are you shiming your differential properly? which bearings are you using for you diff, tapered roller type/ or ball bearings.
if there is too much clearence there will be lateral play and will usually strip the final drive/pinion gear teeth right off...if too tight of a clearence you will usually crack the bearings in half/case damage. I have learned this the hard way.
Old Oct 17, 2006 | 04:14 PM
miller's Avatar
Default Re: ring gears hate me!!!!! (Flexmyrex)
lol, this is funny
Old Oct 17, 2006 | 04:32 PM
tony1's Avatar
Default Re: ring gears hate me!!!!! (miller)
How much backlash are you running on the ring gear? Might need to adjust the pinion gear...
Old Oct 17, 2006 | 04:33 PM
vtekthis's Avatar
donate some ring gears then
Old Oct 17, 2006 | 07:10 PM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">donate some ring gears then </TD></TR></TABLE>
your long list of people who have shown you the way should be able to answer your questions and quide you in the right direction.
Old Oct 17, 2006 | 08:04 PM
boostedh22a's Avatar
Thats odd, I ran 2 seasons on a stock ring and pinion, 26" slicks, 7000rpm launches at about 10psi with no breakages!!!
What clutch setup do you run???
FYI, I did run a H-series, but I wouldn't think they are much stronger.
Old Oct 17, 2006 | 09:11 PM
vtekthis's Avatar
Default Re: (boostedh22a)
tilton cerametalli twin
Quiks66
Honda Motorcycles
11
Jan 3, 2008 06:03 PM
Spec911
Honda Motorcycles
44
Sep 22, 2007 07:45 PM
red eg1
Dec 10, 2005 07:43 AM
integrator43
Honda Motorcycles
15
Nov 27, 2005 04:34 PM
integrator43
Honda Motorcycles
Oct 1, 2005 09:17 AM
