Putting the Bseries vitara's to the test
I don't understand the point of doing all the work and expense of machine work, rods, bearings, gaskets, and skimping on the pistons. I'm glad they do seem to work, but i'd rather spend a extra $200 for a proven 1000+whp piston if going through all the work.
^x2 and i dont under stand why you would do all this to make ~500whp we have quite a few bseries making more than that and there 100% stock short blocks
just find a good tuner
chiming in, 1 year later and my nippon racing CTR replicas are still kicking 235psi across the board, dyno numbers in sig, high boost and 400+hp coming soon!
I build a spare engine for everyday use, like a family car, I don’t want big P2Ws anymore. but I would like to leave the former power.
Can these pistons survive when the EGT exceeds 900 degrees Celsius?
I use CP on my engine, now the power is 430 horsepower at 1 bar. boost.
900c exceeds the 700c'ish melting point of alum so not really a number that matters considering i can turn a steel exh manifold cherry red without making much hp.
Um?? That would depend on what your cylinder temps are!! Exhaust temps give you good data but there is a reason exhaust components are made from steel and the head/piston is made from alum.
What usually do you see EGT at maximum load of their engines?
I want to know some statistics about those engines that are built with NIPON pistons.
Any experience with their other higher compression pistons? I would like to go with a P30 or P73-00 style as I'll be running E85 and a little bit more compression (10.6:1) doesn´t hurt. The engine will be rebuilt and won't see more than 300whp. Are stock rods with ARP bolts fine or Eagle/Scat/Manley rods are highly recommended?
Thank you, that's good to hear. I'm not sure I can post links here, but where would be the best place to get them? eBay? I forgot to say, the engine is a B16, even with the rods being the strongest from the B-Series, I guess the recommendation still stands? With a set of Scat rods, what would be the recommended power level with those pistons and stock sleeves? ~350whp?
There is no max power level. Seen rods break at 300 and seen them live "for a while" at 500... How much of your money do yo want to gamble with??
