Putting the Bseries vitara's to the test
Old Aug 30, 2009 | 06:50 PM
  #51
boostedEF91's Avatar
Default Re: Putting the Bseries vitara's to the test
yes they are the jft rods that brings the pistons to correct compression spec. rather than having eagles that make it very low.
Old Aug 31, 2009 | 02:39 AM
  #52
JDogg's Avatar
Originally Posted by blackeg
lol, but isnt that why the vitaras work so well because they do yeild such a low static compression ratio?
but with standard rods they dont work good, they suck *** in fact.
there is a difference between they work, and they work good, or even work right.
eagles dont make the compression very low, the pistons do. the idea of custom rods so that $200 pistons for the wrong motor work baffles me.
but ill stop thats not the topic of this thread.
So am i reading this correctly that the b-series version of these pistons does have the correct compression height?
Old Aug 31, 2009 | 10:17 AM
  #53
yes.. my compression is 9.6 with these pistons in a type r motor. depending on the head you have and block will vary on compression with these.
Old Mar 8, 2010 | 03:54 PM
  #54
GEN2 LS's Avatar
Loved
bump this thread, i'm wondering how the OP motor is holding up @ this point?
Old Mar 8, 2010 | 04:03 PM
  #55
trickeng's Avatar
the motor still isn't in the car. ??????? not my build, so i have no say. just supplied the part and machine work.
thought it would have been out by now.
Old Mar 8, 2010 | 05:38 PM
  #56
Boston Bastard's Avatar
Im the one doing the car for a friend, but he ran into some money problems. It will be out real soon hopefully in the next month. we'll kept u guys posted
Old Mar 9, 2010 | 11:49 AM
  #57
90dxhmt's Avatar
FJT makes extended rods for the D series to bring the piston back up from its 2 miles down.
Old Mar 9, 2010 | 01:31 PM
  #58
well i've had the nippons in for 1500 to 2000miles at 460whp and there holding up just fine. going to dyno on the 27th to maybe make a lil more with them.
Old Mar 9, 2010 | 03:25 PM
  #59
Professor15's Avatar
where did you get your pistons at?
Old Mar 9, 2010 | 03:35 PM
  #60
http://cgi.ebay.com/ebaymotors/Low-C...Q5fAccessories
Old Mar 9, 2010 | 03:36 PM
  #61
you must tell him when ordering if using stock rods or aftermarket. extra 50 for machine work and the c clips for after market rods.
Old Mar 11, 2010 | 06:07 AM
  #62
solo227's Avatar
YOu might wanna do a lil more research before you continue to run your mouth... Even wit the low compression... People have had great success on vitara setups... The pistons allows for alot more boost to compensate for the lack of compression...
When FJT came out with the pistons... People jumped on it cuz it made the car more peppy outta boost... And those other guys were looking for big HP numbers...
Either way for a budget racer... Vitaras OWN... Nobody said your gonna make a million HP with them... But they get the job done...
Old Mar 11, 2010 | 07:14 AM
  #63
JDogg's Avatar
um way to bring **** back from the dead.
i have been building and tuning turbo honda's for 10 years now and all the research you have read about, i have done.
with standard rods, vitara's are junk, put hte long rods in and they are good for a budget setup.. .just remember that you can never upgrade to a "real" piston.
you realize that with standard rods the compression is down around 7-7.5:1?
Old Mar 11, 2010 | 07:36 AM
  #64
hawkturbo's Avatar
good luck and waiting news jejej
Old Mar 11, 2010 | 10:55 AM
  #65
fast2camciv's Avatar
you realize that standard rods put compression ratio's right around what a dsm is stock right? and you realize that dsm's put out an assload of hp at that compression right? and you do realize that people (including myself) have quadrupled the stock d-series hp with nothing more than vitara pistons and eagle rods right? and you do realize your being ignorant as f#ck right?
those FJT long rods are cheaper than eagles so who f-ing cares? why even open your mouth and waste your time in this thread????
i built my vitara motor for under $600 and made 405whp with simple turbo kit. ANYONE should be able to appreciate that, and give props to someone doing more, with less.
if you cant do that, keep your hater a$$ comments to yourself while the rest of us try new things and keep innovation in the honda world going.
seriously.
Old Mar 11, 2010 | 12:07 PM
  #66
K7-1Ktrevor's Avatar
Loved
Community Favorite
I love budget ****. If I ever build a motor Im gonna do eagles and these in my ls thats a big if though, I want to just do methanol on it and see what I can make on that safely.
Old Mar 11, 2010 | 04:22 PM
  #67
neek175's Avatar
seriously.
A(flippin)men... I just got retuned to over 430 whp on my standard length eagle rod vitara setup and I love it. Out of boost power is no issue at all.
Old Mar 14, 2010 | 09:34 PM
  #68
V-SPEC 1's Avatar
In for results and Trickeng, you got PM.
Old Mar 19, 2010 | 05:44 AM
  #69
hawkturbo's Avatar
any updates ???
Old Mar 19, 2010 | 08:16 AM
  #70
theidealone's Avatar
****, I gotta buddy that went 10.9 last year, at altitude in Colorado- 5800', on a streetable standard Eagle/Vitara set-up. And hell, at this altitude, his compression is probably closer to 6.xx:1.
Keep in mind he's the second fastest D series in Colorado, right behind a fully built and sleeved D series all out race car.
Old Mar 28, 2010 | 05:04 PM
  #71
Put My car back on the dyno Yesterday. Made a few changes from last time i was on the dyno. New Afi Ramhorn manifold. (previously had a ccfab), New Downpipe, Throttle body, and cut a 3 foot section out of my ex in the back. previous tune was 460 and 337 at 20psi on the nippons. New results are 522hp, 369tq on 20psi using 93 pump gas. still Using the nippon pistons. Will post Dyno sheet as soon as i get it from my tuner.
Heres my setup.
81mm b18c typeR, Stock sleeves
stock typeR head
typeR cams
Eagle rods
Nippon pistons
BW S362 NET turbo.
Afi ramhorn
VictorX intake
custom 3in downpipe and ex.
Old Mar 28, 2010 | 05:11 PM
  #72
V-SPEC 1's Avatar
Good job.
Old Mar 28, 2010 | 06:28 PM
  #73
Mr. Em1's Avatar
sounds good man, lets see some videos of this thing in action
Old Mar 28, 2010 | 07:38 PM
  #74
Boosted-EH-804's Avatar
That is pretty badass there man glad to see that they are holding up great for you
Old Mar 29, 2010 | 04:50 AM
  #75
hawkturbo's Avatar
Good congrats nippon for me jejeje
