Prologger experience...
Old Oct 5, 2007 | 08:45 AM
  #26
Billy T.'s Avatar
Default Re: Prologger experience... (tony1)
Can you trigger the prologger with a wheel speed input?
Or maybe it would be easiest to have it start when the two step is released, just use the same button...
We need one of these things bad.
Old Oct 5, 2007 | 09:51 AM
  #27
tepid1's Avatar
Default Re: Prologger experience... (Billy T.)
The Prologger has configurable outputs only (IE: for VTEC, Shift light, Nitrous, ect....). It turns on when it see's a RPM signal and turns off automatically after 5 minutes of no RPM signal.
You can use Input 1 (aka the Launch Control Input) to trigger the recording. 12vdc applied then removed starts the log sequence.
Old Oct 5, 2007 | 09:52 AM
  #28
tony1's Avatar
No, can't trigger by wheel speed, but trigger it with your 2 step button, that's the best way.
Call me Billy
Old Oct 5, 2007 | 10:31 AM
  #29
Kataku2K3's Avatar
Yeah, the ProLogger, VTEC rpm activated switch is cool! Travis' is wired like and you can tell when it's engaged because of the output 1 light!
Old Oct 5, 2007 | 10:38 AM
  #30
tony1's Avatar
Default Re: Prologger experience... (Kataku2K3)
and you can have it turn vtec off if it gets too lean.
Old Oct 5, 2007 | 10:55 AM
  #31
PPLH8R's Avatar
Default Re: Prologger experience... (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">The Prologger has configurable outputs only (IE: for VTEC, Shift light, Nitrous, ect....). It turns on when it see's a RPM signal and turns off automatically after 5 minutes of no RPM signal.
You can use Input 1 (aka the Launch Control Input) to trigger the recording. 12vdc applied then removed starts the log sequence.</TD></TR></TABLE>
The only gripe that I have so far is that the log sequence is triggered by 12v and not a ground. If it was a ground then you wouldnt have to use a relay when used in conjunction with the 2 step.
Old Oct 5, 2007 | 11:04 AM
  #32
tony1's Avatar
Default Re: Prologger experience... (PPLH8R)
Most domestics use 12v signals for the line lock and/or trans brake, i think that's why it's like it is. But yeah, would be nice to trigger with ground w/o using a relay.
Old Oct 5, 2007 | 12:42 PM
  #33
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Call me Billy</TD></TR></TABLE>
but i thought ur name was tony?
Old Oct 5, 2007 | 01:09 PM
  #34
DaveF's Avatar
Default Re: Prologger experience... (wHOAlly)
whats the price on an infared or whatever ground sensor ?
Old Oct 5, 2007 | 06:52 PM
  #35
extremevtecracing's Avatar
That is so true on not having a lot of points on the M4. I remember wanting like 50 things on my Motec and before I knew Tony was telling me "You ain't got enough for that. figure out what you want and actually need and go from there." BTW Tony, i think putting the 2 step was a bad idea like you said. IMAGINE THAT!!!
Old Oct 6, 2007 | 09:21 AM
  #36
Lonnie's Avatar
Default Re: Prologger experience... (extremevtecracing)
How consistant is the boost control?
Old Oct 6, 2007 | 05:04 PM
  #37
tony1's Avatar
Default Re: Prologger experience... (Lonnie)
This one was very consistent and stable right off the bat, without even messing with the overshoot and gain settings.
Old Oct 6, 2007 | 09:38 PM
  #38
Kataku2K3's Avatar
Buy from Tony, he's got the conversion values for the PL and Motec!
P.S. - They worked perfect!
Old Oct 7, 2007 | 07:06 AM
  #39
philipwight's Avatar
i love this unit. we have it on one of our racecars. we use the o2 sensor and output it to the m4 unit. the quick lambda works great. it is an ausie box that wont let you even turn lambda on. we use the rpm output to control vtec and let the m4 control the idle air control valve.
my car has an m400 on it and the oscope has come in handy a few times. if i could find a reason to put a pro-logger on the car i would. maybe for the boost controller......
Old Oct 14, 2007 | 01:47 PM
  #40
blackpearlcivic's Avatar
Default Re: Prologger experience... (philipwight)
Does somebody have pic off the prologger mounted in a car?
Old Oct 14, 2007 | 07:20 PM
  #41
Kataku2K3's Avatar
Default Re: Prologger experience... (blackpearlcivic)
Anybody have the 1V and 4V kpa values for a AEM 5 bar MAP? AEM gave Travis values (around ~-5psi and ~50psi), but those numbers don't come close to zeroing out the ProLogger, or reading the correct boost which the Motec is showing...
P.S. - I did do the conversion from psi to kpa a few different ways. First off assuming that -5psi meant 5psi below absolute (~60kpa) and also just 5psi since I don't know how you can have a negative pressure value. Did the same for the upper voltage too, with several different combinations. ProLogger doesn't like to answer Travis' calls either...
Old Oct 15, 2007 | 05:51 AM
  #42
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlcivic &raquo;</TD></TR><TR><TD CLASS="quote">Does somebody have pic off the prologger mounted in a car?</TD></TR></TABLE>
This is the closest pic i've got of mine right now.
Adam, call me, i'll get you the info you need. Prologger is in the middle of relocating right now and they're kind of hard to get ahold of.
Old Oct 15, 2007 | 09:22 AM
  #43
turboedc2's Avatar
Adam, call me, i'll get you the info you need. Prologger is in the middle of relocating right now and they're kind of hard to get ahold of. </TD></TR></TABLE>
Nice short shifter you got there...
Old Oct 15, 2007 | 01:18 PM
  #44
Thanks Tony for the pic .
Old Oct 15, 2007 | 03:34 PM
  #45
tony1's Avatar
In case anybody else needs the values for the 5 bar map and the prologger.
0 = 65
5 = 500
Thanks to Brent at PFI Speed for the info.
Old Oct 15, 2007 | 04:08 PM
  #46
tepid1's Avatar
Wow, great Prologger pic.... lol
Reynolds mounts his in the same place too.
Old Oct 15, 2007 | 04:12 PM
  #47
redboost10's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">In case anybody else needs the values for the 5 bar map and the prologger.
0 = 65
5 = 500
Thanks to Brent at PFI Speed for the info. </TD></TR></TABLE>
thanks brent and tony. ive been trying to get a hold of prologger, and i also went through a few calls to aem. this should do it though.
Old Oct 15, 2007 | 11:14 PM
  #48
Kataku2K3's Avatar
Default Re: Prologger experience... (redboost10)
Thanks guys! Our closest to that was 72/452.
Old Oct 29, 2007 | 10:17 PM
  #49
Blueprint's Avatar
Default Re: (PFI_NAYR_ONE)
Camp1320 has prologgers in stock for like $575 fully loaded with map sensor and boost options. i got my from them. the only thing is he doesnt know how to use it. i need someone to wire it up too. The thing comes with a bible, i got lost reading it. I was thinking about selling it and getting something else. does anyone in cali tune with it?
Old Oct 30, 2007 | 05:30 AM
  #50
tony1's Avatar
Default Re: (Blueprint)
All you have to do is read the directions....
We used the 5 stage boost control on a FWD daily driven VW last weekend and got it into the 10's, 10.91 @ 134.
