Product Test: Bullseye Power S368 (67mm) vs Garrett GT4294R (70mm)
Old 02-09-2008 | 01:21 PM
Turbo-charged's Avatar
Default Product Test: Bullseye Power S368 (67mm) vs Garrett GT4294R (70mm)
looking to run power street, here is your turbo!!
needless to say, we are very pleased with the results of the S368 from bullseye power / borg warner.
set up on the car is:
GE sleeved block
manley rods
9.5:1je pistons
STOCK GSR cylinder head
STOCK GSR cam shafts
super tech springs/retainers
engine built by John at absolute proformance
inline pro exhaust manifold
4 inch open downpipe
3 inch intercooler piping
Hondata S300
aem 5 bar
s300 boost control
pcs dash logger
here is the GT4294r dyno chart (100% duty cycle on boost control)
here is the S368 dyno chart (90% duty cycle on boost control)
the distributor on the car is showing signs of crapping out, and the tires were spinning pretty decent on this pull as well i think with out spinning the car could make in the 30's
for borg warner / bullseye power
i see us selling a lot of these for the guys running the power street class, and the K-series guys running turbo street!
should hopefully post some pictures of the set up and what not here shortly
Old 02-09-2008 | 01:26 PM
2fastGSR's Avatar
King of the One Liners
Default Re: Product Test: Bullseye Power S368 (Turbo-charged)
Thats impressive.
You guys always do real world tests that help people out. . .
to you sir
Old 02-09-2008 | 01:28 PM
Default Re: Product Test: Bullseye Power S368 (2fastGSR)
thanks, we try.
i guess i should note that ignition timing was untouched.
VE was surprisingly very similar unti i got to about 34lbs or so, then i had to start increasing fuel to achieve the same AFR. i like to run cars at these boost/power levels pretty rich, target air/fuel was around 11.3
Old 02-09-2008 | 01:50 PM
tricura's Avatar
Congrats on the the testing, glad to hear it went well
Old 02-09-2008 | 01:51 PM
BoostedJeff's Avatar
Here is a pic of the turbo and 2 of the test vehicle
Old 02-09-2008 | 02:09 PM
tricura's Avatar
Default Re: Product Test: Bullseye Power S368 (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">Here is a pic of the turbo and 2 of the test vehicle
damn that turbo is small
Old 02-09-2008 | 02:14 PM
fmfkid250's Avatar
how would this compare to a split flange t4/67HO?
Old 02-09-2008 | 02:22 PM
Default Re: (fmfkid250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">how would this compare to a split flange t4/67HO?
The HO on the 67 is for the T3 using the Ptrim exhaust wheel.
This would blow the T4/67 out of the water, I see these maxing out at around 700whp (on an accurate dyno)/150ish mph
Old 02-09-2008 | 02:42 PM
turbodano's Avatar
Default Re: (BoostedJeff)
This would blow the T4/67 out of the water, I see these maxing out at around 700whp (on an accurate dyno)/150ish mph</TD></TR></TABLE>
The Gt4094 was a 70MM unit right?
Old 02-09-2008 | 02:46 PM
E Town DSM's Avatar
Default Re: (turbodano)
What are the Exd size on both units i know the garret is 94mm whats the borg?
Old 02-09-2008 | 03:04 PM
fresh_manny21's Avatar
Default Re: (E Town DSM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E Town DSM &raquo;</TD></TR><TR><TD CLASS="quote">What are the Exd size on both units i know the garret is 94mm whats the borg?</TD></TR></TABLE>
101.9mm ....83.4 and 73.4 for the turbine wheel.
Correct me if im wrong but same specs as a s372 but with a 68mm inducer?
Old 02-09-2008 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">
The Gt4094 was a 70MM unit right?</TD></TR></TABLE>
I don't know if you meant the 4094 or the 4294, but the 4094 is a 67.8mm turbo. The 4294 is a 70.3mm.
Dan, We are extremely impressed with this turbo. Bullseye
Old 02-09-2008 | 03:15 PM
BoostR41's Avatar
Joe can you get the S368 with a T3 hotside? no money for it right now but would like to upgrade at some point if I keep the car and dont want to mess with swaping manifolds
Old 02-09-2008 | 03:17 PM
turbodano's Avatar
Default Re: (fresh_manny21)
No it's nt on the same back. I don't remember what it is off the top of my head. Maybe Jeff could pull the cover off and measure it for us? I think it is around 98 but don't quote me on that.
Old 02-09-2008 | 03:18 PM
streetracer6rpt's Avatar
we all know that bullseye makes more power than anyone... God i love my 372...............thanks
Old 02-09-2008 | 03:19 PM
turbodano's Avatar
Default Re: Product Test: Bullseye Power S368 (BoostR41)
Old 02-09-2008 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">Joe can you get the S368 with a T3 hotside? no money for it right now but would like to upgrade at some point if I keep the car and dont want to mess with swaping manifolds</TD></TR></TABLE>
The exhaust wheel on the 368 is too large to fit in the t3 housing. I have sold numerous T3/S366 turbos, we will be doing some testing on one in the near future as well.
Old 02-09-2008 | 04:05 PM
looking at the 2 charts is a little deceiving..it makes it look like the s368 hit peak boost real late, however it spun the tires at peak torque so its not showing as peak on the graph.
PCS logs showed just what the dyno chart does----spinning the tires right at peak torque, holding power better right after that, and breaking the tires loose again up top.
ignition timing was untouched from the original tune up with the 42r
Old 02-09-2008 | 04:19 PM
BLK JDM's Avatar
Default Re: Product Test: Bullseye Power S368 (turbodano)
I spy a Ford Lightning tow truck and a Blue hatch. I think there's a guy named Ben standing somewhere around the shop w/ a smile on his face!!!
2 thumbs up to Joe Simpson, Jeff, and the whole Tempest Crew!! Stand up guys doing stand up work!!
Old 02-09-2008 | 04:52 PM
Boston Bastard's Avatar
That's damn good Congrats on the the testing
Old 02-09-2008 | 05:50 PM
ModenaTwinTurbo's Avatar
Default Re: Product Test: Bullseye Power S368 (BLK JDM)
the gt42 makes higher average power. alot closer if not some past the diagonal eficiency line in a graph. i cant overlap them i'm sure the poster can on the dyno graph plotting program. what i did was take the info and plot it into my own excel spredsheet n sure enough. the gt42's line is pulled further towards the upper left hand side of the graph.
depending on how much cheaper the other turbo is i'm sure its probably worth it. cuz it sure does seem to be able to make a very similar graph.
Eddie Rosado
Old 02-09-2008 | 06:44 PM
XXXRacing's Avatar
thanks for doing some testing for us joe...looks like I know what turbo will be on the car along with the 200 shot
Old 02-09-2008 | 07:59 PM
Jared's Avatar
do you have the logs for boost, time, speed, etc...?
Old 02-09-2008 | 09:47 PM
IT'S ME DAVID's Avatar
NooB
Steve/antilag was telling be its comparible to the gt40r but I now see it beats the gt42r..I gotta get one of these for sure..
Old 02-09-2008 | 11:05 PM
200TS EC's Avatar
Price vs Price ???
Quick Reply: Product Test: Bullseye Power S368 (67mm) vs Garrett GT4294R (70mm)
