problem with mounting slicks
Old Mar 13, 2004 | 12:59 PM
goose21's Avatar
Default problem with mounting slicks
I've got my slicks today m/t 20-8-14 and i want to mount on some
steel rims(6-14). But when they got the slicks on the rims they
could not get them filled with air. What's wrong?
Old Mar 13, 2004 | 01:22 PM
Jared's Avatar
Default Re: problem with mounting slicks (goose21)
slicks are a bitch to get the bead seated properly. make sure the bead is seating.
Old Mar 13, 2004 | 01:25 PM
goose21's Avatar
Default Re: problem with mounting slicks (Jared)
I'm from holland so my englis isn't so good. whats the bead?
Old Mar 13, 2004 | 03:57 PM
bsracing's Avatar
Slicks are a bitch to bead, what kind of lube are you using?, i use windex so when its beaded the windex dries and the rim is less likley to slip on the tire, also is the core out of the valve stem?
Old Mar 13, 2004 | 04:08 PM
95GLX's Avatar
the bead is the outer part of the sidewall that will go up against the lip of the wheel!
with slicks they will need to use an extra amount of lubricant/soapy water! Just be careful not to over inflate the tires when seating the bead to the wheel!
Anthony
SpeedDreamz.com
Jun 8, 2004 07:37 AM
allmotorhatch
Jan 28, 2003 07:18 AM
DubyaAye
Jan 8, 2003 01:16 PM
CivicEx95
May 22, 2002 05:19 AM
