Problem with DSS stage 5 hubs
Old Jan 7, 2006 | 10:35 AM
Mikey3000's Avatar
Default Problem with DSS stage 5 hubs
so i got a stage 5 axle set from DSS, they come with the axles and hubs and studs. i have a 92 civic cx. the DSS hubs don't have threaded holes for the disc mounting screws (the 2 little ones that hold the disc to the hub). did i get the wrong hubs or what am i supposed to do?
Old Jan 7, 2006 | 11:04 AM
Jared's Avatar
just dont use the screws
Old Jan 7, 2006 | 11:13 AM
Mikey3000's Avatar
Default Re: (Jared)
then how will the discs be mounted to the hubs?
Old Jan 7, 2006 | 11:18 AM
Tyler H's Avatar
Default Re: (Mikey3000)
The caliper will keep them on when the wheel is off. When the wheel is on, the rotor will be held flat against the hub.
Old Jan 7, 2006 | 02:58 PM
Mikey3000's Avatar
Default Re: (Tyler H)
that sounds dangerous. have you done that?
Old Jan 7, 2006 | 03:19 PM
mec. pedri's Avatar
ALOT OF AMERICAN CARS DON'T EVEN HAVE THOSE SCREWS. FOUR LUG NUTS IS MORE THAN ENOUGH TO KEEP EVERYTHING NICE AND TIGHT.
Old Jan 7, 2006 | 03:32 PM
Jared's Avatar
nothing dangerous about it. the screws are only there for ease of installation. the wheel and lugnuts are what actually hold the rotor to the hug.
Old Jan 7, 2006 | 03:39 PM
Mikey3000's Avatar
Default Re: (Jared)
ok sounds good. thanks guys.
Old Jan 7, 2006 | 04:20 PM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">that sounds dangerous. have you done that?</TD></TR></TABLE>
Nope have been running those for two years no problems and brakes work fine.
Old Jan 7, 2006 | 04:25 PM
speedworks's Avatar
Default Re: (underpressure02)
the screws are there to hold the rotor on while going down the assembly line. saves peoples toes
Old Jan 7, 2006 | 05:04 PM
ABK's Avatar
ABK
Default Re: (speedworks)
I never put the screws back into my cars.
Old Jan 8, 2006 | 01:10 AM
The Tea-father's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote">The caliper will keep them on when the wheel is off. When the wheel is on, the rotor will be held flat against the hub.</TD></TR></TABLE>
What he said, we never had any problem with it
Old Jan 8, 2006 | 07:46 AM
2FastxEg's Avatar
i called them up about this along time ago. I can confirm for you that those are only there to hold the disc on when you pull of the wheels off and work on the suspension parts. If you think through how everything works and when you tighten up you wheels onto the hubs, the rotors are then tightened onl....... by the way, did you have any problems putting on the bearing onto the hub? for some reason when i did mine, my bearings just slid right on it, i thought you were supposed to press it in...
Old Jan 8, 2006 | 02:23 PM
Mikey3000's Avatar
Default Re: (2FastxEg)
i havent got that far yet. the old hubs do need to be pressed out and new ones pressed in the knuckle correct?
Old Jan 8, 2006 | 02:47 PM
Missing Gears's Avatar
the new bearings will need to be pressed into the knuckle, then press the hub into both.
Old Jan 8, 2006 | 02:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FastxEg &raquo;</TD></TR><TR><TD CLASS="quote">i called them up about this along time ago. I can confirm for you that those are only there to hold the disc on when you pull of the wheels off and work on the suspension parts. If you think through how everything works and when you tighten up you wheels onto the hubs, the rotors are then tightened onl....... by the way, did you have any problems putting on the bearing onto the hub? for some reason when i did mine, my bearings just slid right on it, i thought you were supposed to press it in... </TD></TR></TABLE>
either tour hubs were very worn, or you had the wrong bearing/ hub combo. either way, no good.
incredteg3
Sep 3, 2007 05:08 AM
boosted2000si
Mar 26, 2006 06:09 PM
hndarcrb18c1
Apr 28, 2005 06:16 PM
drewbie
Feb 8, 2005 02:55 PM
chet
Jun 6, 2003 09:31 PM
